Engine Intakes, Exhausts, Clutches, Turbos, etc...
Hypertech Pocket Tuner, Consider this before ANY OTHER pocket tuner
Old Mar 19, 2010 | 09:49 PM
ImportedPerformance's Avatar
ImportedPerformance
Vendor - Former Vendor
Default Hypertech Pocket Tuner, Consider this before ANY OTHER pocket tuner
Hypertech Max Energy
Power Tuning
Higher compression ratio engines and engines with superchargers or turbo chargers were designed to use only premium octane, so only one (1) Power Tuning program for premium octane is provided. But, if your car came from the factory capable of using more economical regular octane, then two (2) optimized tuning programs are provided: one for premium, and the other for regular. In most cases, Hypertech’s exclusive Power Tuning for regular octane provides excellent power gains, almost as much power as premium octane. If you are using premium octane, and you want all out, maximum power, then select premium octane Power Tuning.
Top-Speed Limiter
Automobile manufacturers limit a vehicle’s top-speed to match the speed rating of the factory-installed tires. If you have installed tires that have a different speed rating, the Max Energy Sport allows you to raise or lower the vehicle’s top-speed limiter to match the speed rating of the newly installed tires. A tire’s speed rating for maximum safe speed under perfect conditions is marked on its sidewall. Always obey all traffic laws when driving.
Return To Stock Or
Change Option Settings
Hypertech’s Max Energy Sport downloads and saves the stock tuning program, then uploads your customized Power Tuning program. Before taking your vehicle into a dealership for service, always return the vehicle’s computer back to the factory programming. Once you have the vehicle back from the dealership, reinstall the Max Energy Power Programming as before. The Max Energy Sport can only be used on one (1) vehicle at a time, so if you sell your vehicle or want to use it on a friend’s vehicle, simply return your vehicle to the stock tuning program and you may then use the programmer on another vehicle that is covered in the same part number.
RPM “rev” Limiter
In today’s vehicles, the onboard computer controls maximum engine rpm. The stock computer is programmed to shut down the engine when it reaches its redline. But if you have modified your vehicle to increase its high-speed performance, more rpm means more power. When you shift gears with the stock rpm limit, the engine falls back to below the peak of its horsepower curve. When you extend the engine’s rpm range with the Max Energy Sport Power Programmer, your engine has more power available after gear changes. By adjusting the maximum rpm to keep the engine in the “sweet spot” of its power curve, you can increase the average horsepower that accelerates the vehicle. Extending the engine’s rpm range also helps you get the maximum power from other bolt-on power adders.
0-60 MPH Electronic
Throttle Restriction
Even though you “floor” the vehicle’s accelerator pedal, the factory programming contains a wide open throttle (W.O.T.) restriction which slowly opens the throttle to W.O.T. for smooth, no wheel-spin acceleration. With the Hypertech Max Energy Sport Power Programmer, this feature allows you to remove the W.O.T. restriction for immediate, maximum throttle response and power, with quicker acceleration. You may have to practice your “starts” to control wheel-spin with stock tires, but with wider rear tires, or at a “sticky” race track, you will definitely get quicker acceleration and elapsed times.
Are you in the market for a pocket tuner that gives you POWER? What about other options such as removing the 0-60 W.O.T. Limiter? The Speed Limiter? What about giving you the option to return to stock settings?
The HyperTech Tuner is what you are looking for then! And right now I have 6 of them at a SPECIAL MY350Z PRICE!
Just enter the promo code "hypertech1" - HyperTech Max Energy Sport, Order Here
$25 in FREE Gift Cards to EACH unit sold!!!
Check out the website : http://sport.hypertech.com/Nissan.aspx
Dyno Chart
Old Mar 20, 2010 | 03:48 PM
ImportedPerformance
Quotes sent, PM's Replied, Packages Sent!!!
PM me let's make you a deal!
Old Mar 21, 2010 | 11:26 AM
ImportedPerformance
Old Mar 21, 2010 | 08:59 PM
ImportedPerformance
Old Mar 22, 2010 | 03:34 PM
ImportedPerformance
Old Mar 23, 2010 | 02:44 PM
ImportedPerformance
PM or e-mail me at s-andrews@live.com to get signed up for the Imported Performance New Letter, special pricing and offers will be in the news letter and NOT OFFERED ANYWHERE ELSE!
Old Mar 24, 2010 | 11:27 AM
ImportedPerformance
Old Mar 25, 2010 | 06:35 AM
ImportedPerformance
Old Mar 25, 2010 | 03:16 PM
ImportedPerformance
Old Mar 26, 2010 | 07:34 PM
ImportedPerformance
Old Mar 27, 2010 | 02:47 PM
ImportedPerformance
Old Mar 27, 2010 | 04:04 PM
james-z33's Avatar
james-z33
Default hi
shipped to 06082
Old Mar 28, 2010 | 09:13 AM
ImportedPerformance
PM or e-mail me at s-andrews@live.com to get signed up for the Imported Performance News Letter, special pricing and offers will be in the news letter and NOT OFFERED ANYWHERE ELSE!
Old Mar 28, 2010 | 09:43 PM
ImportedPerformance
Old Mar 29, 2010 | 03:43 PM
ImportedPerformance
Old Mar 30, 2010 | 04:43 PM
ImportedPerformance
Old Mar 31, 2010 | 10:08 AM
ImportedPerformance
Old Apr 1, 2010 | 02:30 AM
ImportedPerformance
Old Apr 1, 2010 | 03:35 PM
ImportedPerformance
Old Apr 2, 2010 | 11:38 AM
ImportedPerformance
