ProSport Premium Gauges! Our pricing will not be beat.
ProSport Premium gauges offer a great look, value and accuracy. We use these in all kinds of builds and know the owner very well. They stand behind their product very well. Check out some of the gauges from ProSports's Premium line that we have to offer.
52mm Premium Tachometer:
Fully programmable warning function as well as peak recall and only 1.25" deep. Set the warning feature to flash deep red at your designated shift point and use this gauge as a shift light.
Features & Includes:
0-10,000 RPM's
Mounting Cup
Visor
Quick connect pigtail wiring harness
Decal
Instructions
Only Available in Amber/White
52mm Premium Volt Meter:
Monitor you engine functions with one quick glance and notice any problems before your vehicle leaves you stranded. Don't wait for your factory battery light to come on, once that happens you'll be walking home! Now you can set your Volt gauge to warn you if your voltage drops. Fully programmable!
8-18 Volt Gauge
Mounting cup
Visor
Instructions
Decal
52mm Premium Water Temp Gauge:
Powered by a rugged Stepper Movement and utilizing only top grade sending units these 270° full sweep electrical gauges are durable, reliable, safe & easy to install. Monitor your engine temperature with more precision.
Set the warning feature to any temperature you want to warn you before you smoke your motor!!
100°~280°F Readout
Water Temp. Sender
Visor
Mounting Cup
Decal
Instructions
52mm Premium Oil Pressure Gauge:
Don't trust your factory gauge for important monitoring of engine functions. By the time your factory idiot light comes on the damage is already done. Monitor you engine functions with one quick glance and notice any problems before it is catastrophic. Save your engine, set your warning function to go off before you loose all your oil pressure!
That's right this gauge warns you once your oil pressure drops below your set limit
Features and Includes:
0-150 PSI includes Sender
Mounting Cup
Visor/Hood
Decal
Instructions
52mm Premium Electric Boost Gauge:
This ELECTRICAL Boost Gauge will perform a pointer sweep/self check on start-up & shut down! If your vehicle is supercharged or turbocharged then this gauge is simply a must have. For peak performance you need to know how much boost you are making at maximum RPM's. Now you can track your peak boost as you modify your ride!
Save your Turbo-Set the warning function to alert you when you over boost!!
-30~30 PSI
Mounting Cup
Tubing kit
T-Adapter
Electric Sender
Visor
Decal
Instructions
52mm Premium Oil Temp Gauge:
Powered by a rugged Stepper Movement and utilizing only top grade sending units these 270° full sweep electrical gauges are durable, reliable, safe & easy to install. Monitor your engine temperature with more precision. Keep hazardous fluids out of the passenger compartment.
Blacked out when off
100-300*F Temp Range
1/8" NPT Temp Sender Unit
Mounting Cup
Quick Connect Harness
Visor
Instructions
Decal
We will always do what we can to match or beat any advertised price! ProSport Gauges ship daily and we can get you any combo that you could need. Please let me know if you have any questions.
Thanks for your time and consideration.
0-10,000 RPM's
Mounting Cup
Visor
Decal
Instructions
8-18 Volt Gauge
Mounting cup
Visor
Instructions
Decal
100°~280°F Readout
Water Temp. Sender
Visor
Mounting Cup
Decal
Instructions
Mounting Cup
Visor/Hood
Decal
Instructions
-30~30 PSI
Mounting Cup
Tubing kit
T-Adapter
Electric Sender
Visor
Decal
Instructions
Mounting Cup
Visor
Instructions
Decal
