Engine Intakes, Exhausts, Clutches, Turbos, etc...
Injected Performance Catch Can Kit!!!!
Old Jan 26, 2011 | 11:13 AM
InjectedPerformance's Avatar
InjectedPerformance
Vendor - Former Vendor
we do have an HR in here now and will take a look into what it would take to mount one there
EDIT: Well I took a quick glance and it will not work on the HR in the engine bay, they would work in the fender well area and if the bumper has to come off this car I will get a better idea of the install potential.
Old Jan 26, 2011 | 11:22 AM
IslandZavage's Avatar
IslandZavage
Originally Posted by InjectedPerformance
we use -6 on the generic kit but can set you up with a -10 kit, do you want it in black as well and I will work you up a quote?
Thanks
Dustin
is Blue possible? 33076?
Old Jan 26, 2011 | 11:38 AM
InjectedPerformance
the typical red and blue AN fittings are the only other option
Old Feb 23, 2011 | 12:59 PM
Tomek350Z's Avatar
Tomek350Z
so any update on the HR
Old Feb 28, 2011 | 07:00 PM
BabyZiLLa's Avatar
BabyZiLLa
Do you have to move any rad hoses for this? Looks like where it mounts I have a factory harness and rad hose.
Old Mar 1, 2011 | 05:16 AM
InjectedPerformance
Tomek350Z--- no progress on the HR kit
BabyZiLLa--- the factory coolant hose and harness get tucked behind the bracket.
Old Mar 2, 2011 | 11:10 AM
BabyZiLLa's Avatar
BabyZiLLa
Great. I just ordered one.
What do you guys usually use to plug the intake tube since you disconnect the hose running to the drivers side rocker cover?
Old Mar 2, 2011 | 11:24 AM
InjectedPerformance
BabyZiLLa--- call me back about your order... we have not received the email you spoke to me about...
You can get an assortment of caps at any local auto parts place. Depending on the intake and intake plenum installed in the car depends on what size you need.
Old Mar 2, 2011 | 11:38 AM
BabyZiLLa's Avatar
BabyZiLLa
You'd be surprised what you can/cannot get in this town. It's too the point where I'm considering ordering my groceries and toilet paper online.
E-mail re-sent. Thanks mate.
Old Mar 8, 2011 | 06:25 AM
InjectedPerformance
More back in stock, thanks for the orders.
Old Mar 10, 2011 | 11:43 AM
BabyZiLLa's Avatar
BabyZiLLa
Does the kit come with the fitting/adapter for the drivers side factory line to the braided line? If not can you tell me what size It is so I can pick one up before it arrives.
You can see what I mean in Cux350z's pictures. I'm guessing the line included with the kit isn't long enough to reach straight to the drivers side rocker cover.
Old Mar 10, 2011 | 11:56 AM
InjectedPerformance
The kit comes with that adapter as well
Old Mar 16, 2011 | 12:10 PM
BabyZiLLa's Avatar
BabyZiLLa
Since I went to like 8 different automotive stores before I could find what I needed, figured I'd post up to save others some time.
If you have the stock intake tube you'll need to cap off the plug on the intake tube and the one on the intake manifold.
NAPA sells Bypass Caps that fit perfect. I couldn't find them anywhere else.
Intake Tube - 5/8" PN: 660-1696
Intake Plenum - 1/2" PN: 660-1697
Old Mar 24, 2011 | 11:09 AM
BabyZiLLa's Avatar
BabyZiLLa
Didn't realize the lines weren't pre-cut..
What do you guys use to cut the line? Don't want to to fray to hell.
Old Mar 24, 2011 | 11:18 AM
InjectedPerformance
a razor blade
Old Mar 24, 2011 | 11:24 AM
BabyZiLLa's Avatar
BabyZiLLa
I've never used this particular hose but previous hoses would fray like a mother with a razor blade. I'll give it a shot.
I'm impressed with the quality of the catch can. It was definitely worth the 3 weeks it took (thanks customs).
Old Mar 24, 2011 | 11:34 AM
InjectedPerformance
atleast you didn't pay double for it, had it gone UPS, but a nice new razor blade makes it very clean, very minimal fray
Old Apr 2, 2011 | 10:20 AM
  #38
BabyZiLLa's Avatar
BabyZiLLa
Can you do me a favour mate and tell me what kind of line it is you guys use in your kit? I'm guessing it's from Earl's but which one.
It's so easy to work with I want to use it for some other things.
Old Apr 4, 2011 | 06:31 AM
  #39
InjectedPerformance
We have a couple suppliers, it is a Prolite 350 style line. $5.5/ft we stock it, if you would like to order some.
Thanks
Dustin
Old Apr 28, 2011 | 06:22 AM
  #40
InjectedPerformance
Bump!
