Engine Intakes, Exhausts, Clutches, Turbos, etc...
Injected Performance Catch Can Kit!!!!
Old Dec 10, 2010 | 07:04 AM
InjectedPerformance's Avatar
InjectedPerformance
Vendor - Former Vendor
Default Injected Performance Catch Can Kit!!!!
We offer this baffled catch can setup for your Nissan 350Z or Infiniti G35 as an attractive and functional method for controlling oil blow-by. Slack is included with each line to allow for custom re-routing, if necessary, although we have chosen lengths suitable specifically for most engine bays. A mounting bracket allows for a clean mount to the front timing cover, and a drain hose allows for easy drainage while performing your oil changes.
Note: This item may not be a direct bolt-in fit for your specific engine bay. Minor hose adjustment may be required. If you have special needs for a catch can setup, please let us know so that we may tailor the product as best as possible.
$189.00 shipped
You may send paypal to: sales@injectedperformance.com (we must ship to confirmed addresses) or feel free to give me a call to place the order.
Thanks
Dustin
888-465-7373
Old Dec 10, 2010 | 10:19 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
looks sweet
hoses are routing to where on your setup? any internal baffling?
Old Dec 13, 2010 | 05:51 AM
InjectedPerformance
Thanks, hoses are routing to each valve cover, no mod's necessary, yes it is internally baffled:
Old Dec 13, 2010 | 08:02 AM
Z1 Performance
Former Sponsor
really nice work, looks great
Old Dec 14, 2010 | 12:45 AM
BlueDragonZ's Avatar
BlueDragonZ
Any other hose color and fittings available?
Old Dec 14, 2010 | 05:34 AM
InjectedPerformance
thanks Z1
BlueDragonZ--- pm me what you are after and we should be able to put a package together to your liking
Old Dec 17, 2010 | 06:39 AM
InjectedPerformance
keep the sales rolling!
Old Dec 17, 2010 | 09:42 AM
Tomek350Z's Avatar
Tomek350Z
anything for the HR motor because i think you would need different mounting points then
Old Dec 20, 2010 | 01:48 PM
InjectedPerformance
we don't have an HR motor in the shop at the moment but can have a few scheduled to drop off next month for motor builds and will be doing something at that time
Old Dec 25, 2010 | 09:11 PM
Tomek350Z's Avatar
Tomek350Z
alright because id be really interested, please contact me if anything comes up
Old Dec 25, 2010 | 09:26 PM
fastintentions4's Avatar
fastintentions4
I would be interested if you can get the stainless hose lines
Old Dec 27, 2010 | 05:17 AM
InjectedPerformance
^ pm sent, yes we can do stainless lines
Old Jan 8, 2011 | 12:33 AM
BlueDragonZ
PM sent...
Old Jan 8, 2011 | 10:31 AM
G Coupe's Avatar
G Coupe
PM Me a price with stainless braided hoses shipped to 92673
Old Jan 10, 2011 | 11:10 AM
InjectedPerformance
^ same price for stainless steel line kit
Old Jan 22, 2011 | 07:26 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I powder coated mine. Picture makes it look purple but it is actually more like the old TN piping. It looks gloss black from afar but then has a translucent black chrome look.
Did the support bracket as well.
installed:
Dont mind the dirty engine bay.
I routed my lines to the passenger side valve cover and to the plenum. Removed one oem hose to install this. I had plenty of line left for the drain hose and was able to bend it up and place it where the oem radiator overflow hose was. Tight fit and no zip ties needed.
Old Jan 24, 2011 | 06:59 AM
InjectedPerformance
Looks Great!
Old Jan 24, 2011 | 08:39 AM
Total D's Avatar
Total D
What size hose/ fittings are being used with this kit? Looking for a -10 setup. Thanks
Old Jan 24, 2011 | 08:53 AM
InjectedPerformance
we use -6 on the generic kit but can set you up with a -10 kit, do you want it in black as well and I will work you up a quote?
Thanks
Dustin
Old Jan 26, 2011 | 09:58 AM
Tomek350Z's Avatar
Tomek350Z
any update for the HR?
