Engine Intakes, Exhausts, Clutches, Turbos, etc...
Sikky LS Swap Kit
Old Aug 12, 2011 | 03:12 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Sikky LS Swap Kit
With the 350Z being such an affordable chassis nowadays, and the desire for enthusiasts to think outside of the box when it comes to modification, an LS swap is a no-brainer. American V8 brawn with the smooth looks of the 350Z, gives you a potent monster for street or track!
Sikky has thoughtfully designed their kit to cover all the "what-if's". The full kit includes:
Aluminum Race Oil Pan
•8 quart high capacity design
•6061 CNC machined flanges
•Baffle and trap doors to prevent oil starvation
•New OEM oil pan gasket
•Oil pickup
Remote mount filter Kit
•8 AN fittings (2) and stainless braided lines (2)
•Remote oil filter base
•High quality oil filter
•All fittings and hardware
Engine Mounts & Transmission Mounts
•CAD/CAM designed CNC machined solid 6061 T-6 aluminum mounts
•Urethane Bushings
•High Grade Hardware Kit
•Proper Engine Placement and Axle Alignment
•Lifetime Warranty on engine mounts
Trans Mount
•CAD/CAM designed
•Steel mount bracket
•Urethane bushing (solid aluminum option available as well)
•High Grade Hardware kit
•Designed for use with the T56 transmission
•Lifetime Warranty on transmission mount
Billet Short Shifter
•6061 Aluminum Shifter plate
•T304 Stainless steel shifter
•Designed for use on the T56 transmission
Driveshaft
•Aluminum One Piece Driveshaft with high strength 1310 U-joints
•Drive shaft length is set up for use with a T56 transmission
We also offer all the ancillary parts you'll need for the install, and can package it together for you in a cohesive package
Need some tuning goodies for your LS? Let us know!
EnjukuRacing
Sep 30, 2015 06:55 AM
