FS: Haltech ECU (Red Box) & Dual Channel Wideband
Old Dec 27, 2011 | 02:35 PM
jarrodh77's Avatar
jarrodh77
Default Haltech ECU (Red Box) & Dual Channel Wideband
SOLD SOLD SOLD
I have for sale a Haltech ECU. It is the older red version. The harness has been cut, so it is no longer plug-and-play and will need some wiring work. I'm pricing it accordingly.
SOLD
I also have a Haltech Dual Channel Wideband controller with 2 O2 sensors. It sells here for $300: http://www.z1auto.com/prodmore.asp?m...mt&prodid=4770. Again, the wiring has been cut on the controller and the sensors, so I'm letting it go cheap.
SOLD
Old Dec 27, 2011 | 04:11 PM
08NismoZ's Avatar
08NismoZ
So everything is there for the wideband kit it just needs the two ends wired back together?
Old Dec 27, 2011 | 04:20 PM
jarrodh77's Avatar
jarrodh77
Yes, the wideband kit appears to be an easy fix. The 4 loose wires are the "power, ground, output to ecu, and dimmer" mentioned in the ad. You would just need to connect the bundles that go to the sensors. I got this 2nd hand, so I don't know who the idiot was that decided to cut them instead of just separating them at the connectors.
Old Dec 27, 2011 | 06:28 PM
SurraTT's Avatar
SurraTT
pm sent
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
