FS: Going LS1, need to clean out garage
Old Aug 26, 2012 | 04:26 PM
Lightning Guy's Avatar
Lightning Guy
Default Going LS1, need to clean out garage
ok folks I have been hunting for power on the NA VQ forever and finally conceded. Started the swap to an LS1 this weekend, so I no longer have any use for these goodies:
New BNIB HALTECH platinum + Dual Wide Band controller + 2 O2s + on Board IO harness, never been installed, $2500
one Stock injector harness and one harness that works on RC injectors, $50 each
Injected Performance "Cosworth Plenum Spacer" $65
JWT flywheel, needs new friction ring, $225
2 crawford V6 plenum covers. The one on the left, needs repowdercoated, it used to rub my hood, the one on the right has been "opened up" for larger Throttle body, but will still accept stock Throttle Body, $250@ Edit, the one on the left has sold
Modified Momentum Performance CAI, notice it does NOT neck down to 2.75" for the MAF sensor, it is a Full 3" all the way, $250 Sold
3 TPMS sensors, $50@
brake booster & Master Cylinder, $200
6 440cc RC Injectors, $200
3 plenums, from left to right, ported MR1Sold, stock MR2, & stock MR3, $100@
This is part of the porting on the MR1
Lowered Motor mounts, lowers the motor 5/8", $50
AMS Radiator, $75 Sold
Stock Drive shaft, $200
4 15mm wheel spacers, $50/pair
2 throttle bodies, $75@
transmission Xmember, $25
Momentum Performance Tranny Mount, $100
Momentum Performace Y pipe, $300
2 Z tubes, $50@
everything is plus fees and Shipping.
Other things i have but do not have the appropriate picture with name/date:
Kelford 189-B cams
BC valve springs and retainers
APS fuel rails
Custom heater core bypass & pathfinder mod
Custom PS relocation
I'll add these later with the correct paperwork.
Old Aug 26, 2012 | 06:19 PM
block8head's Avatar
block8head
Holy pictures,cant see a thing you're selling...
Old Aug 26, 2012 | 06:40 PM
Lightning Guy
too big? Chrome re-sizes them for me, I guess I need to manually re-size them
Old Aug 26, 2012 | 08:03 PM
jblz's Avatar
jblz
Originally Posted by Lightning Guy
GL man.
Old Aug 26, 2012 | 08:17 PM
Russ@Z1's Avatar
Russ@Z1
That radiator needs to find it's way to me.
Also, we need to trade upper air intake pipes.
Old Aug 26, 2012 | 09:38 PM
ImWeeZzel's Avatar
ImWeeZzel
what about the motor, is it for sale?
Old Aug 27, 2012 | 01:46 AM
Lightning Guy
the motor has a "noise", I think it is a bent rod but i haven't torn into it yet. It is not healthy though. That was the catalyst for the motor swap
Old Aug 27, 2012 | 02:00 AM
Lightning Guy
Russ I can bring the radiator to ZNatZ.
You can buy the whole modded MP CAI and then sell yours :P
Old Aug 27, 2012 | 04:03 AM
Russ@Z1's Avatar
Russ@Z1
Don't make me kick you. lol
Old Aug 27, 2012 | 04:08 AM
Lightning Guy
swing batter batter, swing!
Old Aug 27, 2012 | 06:06 AM
ImWeeZzel's Avatar
ImWeeZzel
Thanx for being honest good luck w/your build
Old Aug 27, 2012 | 06:07 AM
Lightning Guy
once I tear into it and know more I'll post more. my luck it is just the chain tensioner, but I've made up my mind on going LS1, so no turning back now
Old Aug 27, 2012 | 06:26 AM
Kwame's Avatar
Kwame
I'd like to see that custom PS relocation if possible.
Old Aug 27, 2012 | 06:30 AM
Lightning Guy
Here ya go sir.
OEM tensioners, and even Nissan OEM belts, pathfinder and sentra I think.
Old Aug 27, 2012 | 08:47 AM
mexicutioner350's Avatar
mexicutioner350
Default radiator
i will take the radiator please money is ready and paypal ready please email me at josefc1991@gmail.com will buy today thanks
Old Aug 27, 2012 | 08:49 AM
mexicutioner350
also how much for retainers srings that you said were BC and APS fuel system as well interested as well thanks
3vilbunny
Jul 18, 2017 05:10 PM
_bit
Oct 2, 2015 07:49 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
