(OEM) FS: ARP studs, throttle body, A/C, coilpacks, starter and gaskets
Old Sep 19, 2012 | 01:33 PM
Zphanatic's Avatar
Zphanatic
Default ARP studs, throttle body, A/C, coilpacks, starter and gaskets
Check out my other FS threads! Pm to contact me!
ARP main studs for VQ35DE. Good condition with all hardware. $100
ARP L19 headstuds for VQ35DE. Good condition with all hardware. $100
6 VQ35DE coil packs. All good condition. $50
All 4 O2 sensors for VQ35DE. All good condition. $40 a piece
VQ35DE A/C compressor. Holes have been plugged to keep trash out. $100
VQ35DE throttle body. Good condition works fine, always do throttle re-learn when messing with the throttle body on these cars. $100
Misc. OEM gaskets brand new.
-Motordyne lower plenum thermo gasket
-Upper plenum
-Thermo x2
-Driver side water pipe
-Center of block water plate
-Front main seal
-Oil cap spill ring x3
-Fuel pump o-ring
$$Make offers$$
Greddy powersteering cooler. New never used. $20
350Z steering knuckle brand new from Nissan. $40
VQ35DE OEM starter. Used but in perfect working condition. $100
VQ35DE engine harness. A couple of plugs are missing. List follows...
Plugs missing:
-Powersteering sensor
-Transmission plug for sensor on the farthest end of the trans
-O2 sensor plug 1 of 4
-Maybe a/c connector
$50
Old Sep 20, 2012 | 04:15 PM
johndoesdamage's Avatar
johndoesdamage
Miles on cat 02 sensors? Throttle body?
Old Sep 27, 2012 | 02:15 PM
Zphanatic's Avatar
Zphanatic
bump
Old Oct 1, 2012 | 06:11 AM
Zphanatic's Avatar
Zphanatic
bump
Old Oct 1, 2012 | 08:57 AM
potsniper's Avatar
potsniper
will take the head studs just need pay pal info
Old Oct 1, 2012 | 06:05 PM
chriswagner92's Avatar
chriswagner92
does the throttle body make a buzzing noise when the key is turned to on, if not then ill be interested
Old Oct 3, 2012 | 08:55 AM
Zphanatic's Avatar
Zphanatic
All questions answered through pm, thanks!
Old Oct 15, 2012 | 05:23 AM
Zphanatic's Avatar
Zphanatic
bump
Old Oct 20, 2012 | 07:18 AM
dorrifto's Avatar
dorrifto
Have you ever manually pressed and opened the butterfly valves on either throttle body? I did that to mine and then learned that it messes it up. The car still runs and drives, but start-ups are rough.
Let me know if one of them is untouched, and pm me
Also, what year did the TB and wiring harness come off of?
Old Nov 13, 2012 | 12:46 AM
shydork808's Avatar
shydork808
do u still have the ARP main studs and the L19 head studs kits still avaliable?
Old Dec 6, 2012 | 06:43 AM
Max Streets's Avatar
Max Streets
are the studs around
Old Dec 6, 2012 | 02:51 PM
13ino13's Avatar
13ino13
I'm interested in the L19 head bolts if you still have them for sale.
Old Dec 17, 2012 | 08:19 PM
350beaZt's Avatar
350beaZt
Still got the starter? How many miles?
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
