FS: Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech
Old Oct 9, 2012 | 09:25 AM
slopefunk55's Avatar
slopefunk55
Default Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech
I have for sale the follow left.
Crawford Plenum - 185 shipped stateside (FIRM)
It has a broken coolant bolt hole. The bolt hole does not effect the manifold pressure. You will have to run a coolant bypass or have it fixed.
05 lower non revup intake(both pieces) - 115 shipped stateside
I can include a new gasket kit for another 20
CJM Fuel Pump output fitting - 50 shipped stateside
cjm return fuel correction kit - 65 shipped stateside
or both for 110 shipped
Stock fuel rails - 40 shipped state side
Thes have had the ends cut off. I will include 4 -6an steel fittings require weld. (cheap DIY -6 rails for fuel return)
Vortech 3.12 pulley - 60 shipped stateside
I also have very low miles vortech serpintine pulleys(1 new) - 30 shipped
or 80 shipped for everything
Rear O2 sensors with code fowlers - 40 shipped
Stock 05 <35k O2 sensors
Aluminum alternator pulley - 15 shipped
no brand listed on part
Attached Thumbnails Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech-000_0045.jpg   Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech-manifold-201.jpg   Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech-manifold-202-20and-20cjm-20kit.jpg   Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech-pulleys-20and-20camber-20bars.jpg   Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech-fuel-rails.jpg
Old Oct 9, 2012 | 01:23 PM
slopefunk55
Default new pic plus a stock 05 throttle body for sale
I have everything else just some stuff is boxed already from sales falling out.
Throttle - 35 shipped stateside
Stock working throttle of my 2005 35k z
Attached Thumbnails Crawford plenum 05 lower manifold CJM fuel return stock rails 3.12 vortech-everything.jpg
Old Oct 14, 2012 | 02:11 PM
slopefunk55
Bump
Old Oct 16, 2012 | 07:33 AM
slopefunk55
Bump
Old Oct 17, 2012 | 02:19 PM
slopefunk55
bump
Old Oct 19, 2012 | 07:58 AM
slopefunk55
Bump
Old Oct 20, 2012 | 07:19 AM
dorrifto's Avatar
dorrifto
Have you ever manually pressed and opened the butterfly valves on either throttle body? I did that to mine and then learned that it messes it up. The car still runs and drives, but start-ups are rough.
Let me know if one of them is untouched, and pm me
Old Oct 21, 2012 | 05:25 PM
slopefunk55
Default bump
Bump
The throttle has never been touched. I smashed up my car and insurance let me pull my parts. It was attached to my Crawford when pulled.
Old Oct 24, 2012 | 06:02 AM
slopefunk55
Bump
Old Oct 25, 2012 | 06:07 AM
slopefunk55
Bump
Old Oct 31, 2012 | 02:50 AM
slopefunk55
Bump
Old Nov 4, 2012 | 06:22 AM
slopefunk55
Crawford sold
Old Nov 5, 2012 | 07:15 PM
slopefunk55
Bump
Old Nov 5, 2012 | 07:17 PM
jhp5081's Avatar
jhp5081
how do i create a new post or thread?
Old Nov 8, 2012 | 07:00 AM
slopefunk55
Click reply and. ........bump
Old Nov 8, 2012 | 09:04 AM
bgant3's Avatar
bgant3
pm'd
Old Nov 9, 2012 | 06:07 PM
slopefunk55
Bump
Old Nov 10, 2012 | 01:35 PM
slopefunk55
Cjm fittings sold
Old Nov 13, 2012 | 07:43 PM
slopefunk55
Bump
Pulley is new and i still.have the unopened gasket kit for the stock plenum
Old Nov 14, 2012 | 09:45 AM
slopefunk55
bump
I also have mud guards stock new unopened fronts and rears and a grey interior subwoofer panel
