FS: Lot of 650+rwhp VQ35 internals, bearings/rods/pistons/gasket/L19/springs
Still avail:
Plenum
ACT brand new PP + disc
ACT flywheel + PP + clutch (barely used)
1600 cc injectors
Complete VQ35DE motor
Forged internals
L19 studs
etc...
Plenum
1600 cc injectors
Forged internals
L19 studs
etc...
Also still available:
Brand new Cosworth headgaskets
Brand new HR headbolts (same strength as ARP2000 but not as strong as L19 studs)
VQ35DE gearbox, low mileage
SOLD
Bottom end:
- ACL race bearings, main, rod, thrust
- ARP Main studs
- BC Sportsman rods, rated for 1200+ hp
- Carillo CP Pistons w pins and rings, 96mm bore, 11:1 comp (if you use with turbo, run high octane gas or E85)
Heads:
- Valve springs w titanium retainers for high rpm and will hold against boost
- Cosworth HR headgaskets (a must if you don't want to keep blowing gaskets)
- L19 studs (also a must if you don't want to keep blowing gaskets)
Bottom end:
- ARP Main studs
Heads:
Any chance you could give me a price on this installed in the DE motor you are selling? Would like everything here on just the long block from the other thread. You keep all parts pulled from the other block. Shipped to 73127?
I have no time which is why I'm letting this stuff go a good amount below vendor pricing. Happy to ship to your engine builder of choice but then buyer has to take it from there.
Used ACT flywheel gone.
Used ACT pressure plate gone.
Barely used ACT racedisc available, $95.
Barely used ACT ProLite 13 lbs flywheel available, $425.
Brand new extreme heavy duty ACT PP+disc available, $625.
The pullout is not available anymore. Parting it out. Almost everything sold.
The following is available:
Cosworth fuel rails
Low mileage excellent condition VQ35DE motor (compression tested, all cylinders within 5 psi)
Low mileage good condition 6 speed gearbox
ACT clutch kit (ProLite 13 lbs flywheel and heavy duty pressure plate + race disc)
