Installing Oem Rear Spoiler
Old Nov 25, 2004 | 03:50 PM
DAYTONA-ZED's Avatar
DAYTONA-ZED
Default Installing Oem Rear Spoiler
I have the factory rear spoiler kit that came with my car. I noticed it comes with two support struts for the hatch and instructions included to install them. Are these heavier duty struts??? If so does the factory wing put that much additional weight on the rear hatch that you cannot use the factory equiped struts that originally came installed on the car???
Old Nov 25, 2004 | 03:52 PM
aws6000's Avatar
aws6000
Yes, they're heavier duty struts. And yes, the extra weight does require the struts.
Old Nov 25, 2004 | 04:14 PM
DAYTONA-ZED
Thanks. Thought i had read they were replacements to handle the additional weight ,but was not sure.
Old Nov 25, 2004 | 08:53 PM
Z04's Avatar
Z04
but that OEM spoiler weighs next to nothing at all, don't see why you need stronger struts unless you are gettimg a NISMO spoiler
Old Nov 26, 2004 | 04:53 AM
aws6000's Avatar
aws6000
It doesn't weigh too much, but it's all about leverage. With all the weight at the end of the hatch, a bit more resistance is needed to keep the thing open. Installing the struts has to be the easiest part of the install.
Old Nov 26, 2004 | 11:41 PM
Strife350z's Avatar
Strife350z
you don't need the struts... just take out the 5lb ballast in the hatch (remove the plastic trim from the inside and you can't miss it)
AchilleZ
Oct 11, 2015 09:45 AM
dcains
Sep 21, 2015 09:28 AM
Suffolk350z
Sep 13, 2015 02:43 PM
