Technical Headlight Question. Need Help!!
I have a base and did the oem xenon conversion about a few months ago. Just the other day for the first time, my left headlight has like super condensation in it. I was wondering, since I cut a hole in the headlight for the ballast to connect to the bulb, I am sure that the condensation is because of this. Now when I see a real oem xenon headlight there is no hole in the back of the headlight conver. I was wondering how does the oem xenon headlight wiring looks. I know that the ballast is located under the headlight housing on the xenon housings. If someone has a picture of this, it would be very helpful.
the housing arent sealed per se. but humidity shouldnt get in. maybe a small bit of water did get in, itll take a few days or weeks to work its way out. if it continually gets in, then you have a problem the hole must be in a place that is often exposed to water. and youll have to seal it somehow with a grommet or some silicone or something.
ILoveDrifting
Sep 7, 2015 03:15 PM
