Tapping a 12v source in the car and installing a switch?
Old Dec 25, 2004 | 08:22 PM
rummya87's Avatar
rummya87
Default Tapping a 12v source in the car and installing a switch?
im a newb at electric type stuff and im learning quickly. I'm trying to install interior lighting for my Z and i wanna know how/where to hook up the lights (12v power) with a switch ... i was thinking fuse box/ignition/cig lighter but i wanna know the actual way to hook up these wires and how to install a switch. I've been searching the forums and have seen a few things that have helped but nothing major. thanks in advance!
-Rami
Old Dec 25, 2004 | 10:19 PM
B-Unit's Avatar
B-Unit
go behind the center console where the sterio head unit is, usually theres tons of 12v goodies back there. If you have a cig lighter or anything just tap into it.
Old Dec 26, 2004 | 05:38 AM
rummya87's Avatar
rummya87
when you hook the wires together ... do you solder them or twist them together or plug them in or what?
Old Dec 26, 2004 | 07:09 AM
Srivero297's Avatar
Srivero297
whenever i work with wires I use blue/yellow connectors. They hold the best from my experience, and they are quick and easy to work with.
Old Dec 26, 2004 | 08:19 AM
rummya87's Avatar
rummya87
i actually ended up deciding to use a dedicated 10 gauge line from the battery to a fuse box which will run to a switch which will connect my lights.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
3vilbunny
Sep 13, 2015 12:31 PM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
