Have anyone remove their ...
Old Jan 17, 2005 | 01:50 PM
LaoSiFu's Avatar
LaoSiFu
Default Have anyone remove their ...
Have anyone here remove their gauge cluster before? I was trying to do it today and have no luck. Maybe someone with experience can write me up a guide. Thanks I would appreciated that.
Old Jan 17, 2005 | 05:43 PM
tonester1011's Avatar
tonester1011
CF God
its pretty easy....not sure which is first because i did it so long ago but the under part of the steering wheel needs to come off and the under part of the dash too...once u start u should be able to tell which needs to come off first...look under your dash, u will see like 4 or 5 bolts that are underneath,...they are easy to see and its obvious which ones they are, 10mm they are i believe...then unscrew the plastic from under the steering wheel, there are 4 phillips screws that require a long screwdriver to get so u may not see the actual screw head but u will see the holes when looking under the steering wheelthat hold that on, after u remove them the rest of the under part just pulls off as well as the steering wheel piece...dont be scared to pull, start at the bottom and work your way to the top...when those pieces are off u can look under the gauges and see 4 bolts, one on each side of the steering wheel that hold the gauges on, once those are off the gauges slide up. I thought it was going to be much harder then it actually was when i did it...just gotta take your time and eventually u will figure it out.
Old Jan 17, 2005 | 05:47 PM
tonester1011
CF God
sorry, there are 2 bolts on either side of the steering wheel underneath, 4 alltogether and when u take those out and start to slide the gauges up u will need to unclip the wire harness from the back of the gauges to get them 0ut
Old Jan 19, 2005 | 03:51 AM
Jun's Avatar
Jun
yup, i have a how-to guide that i made. e-mail me if interested. jun.tanaka@gmail.com
Old Jan 19, 2005 | 04:20 AM
trn's Avatar
trn
Heres a link to a guide with pics
http://liljerk.morpheus.net/350Z/dash_removal/
Hope this helps.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
