Need help with Nismo wing.
Old Feb 28, 2005 | 06:40 AM
maximumsportZ's Avatar
maximumsportZ
Question Need help with Nismo wing.
You know how the wing is 2 pcs, when u bolt down the wing to the base does it matter which bolts u tighten down first? Because on mine one side touches the car, but the other sits up a little higher. When I get home I'm going to remove it and loosen the bolts... Maybe I should do the first 2 on both sides that way the wing will be down as possible then do the backs...
If anyone who's installed the nismo wing first hand and knows what I'm talking about please give me some imput.
Thanks.
Old Feb 28, 2005 | 07:07 AM
FairladyZ's Avatar
FairladyZ
The shop did mine. It should be even. I would tighten the bolts the same amount (do one bolt then the other), alittle at a time. That way it comes together the same. Like putting on your wheel.
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
hardkicks
Sep 20, 2015 12:28 PM
