Swapping Seats
Old Mar 11, 2005 | 11:23 PM
Armitage's Avatar
Armitage
Default Swapping Seats
I have a set of Sparco Torino's I would like to transfer to the Z when I get her. Obviously, I know I will need new mounting brackets and such.
My main concern is thought I read somewhere that there is a problem removing seats because of airbag sensors or something. I ordered my Z w/o the side or curtain airbags. If I want to swap the seats, will I have any problems in regards to alarms being set off?
I did a search and nothing came up, which suprised me seeing how long this site has been active. Thanks in advance.
Old Mar 11, 2005 | 11:32 PM
gt3's Avatar
gt3
If you have seat airbags, I believe you will set up the airbag warning light once you replace the seats with aftermarket ones. If you don't have seat airbags, you should be fine.
Old Mar 12, 2005 | 05:12 AM
skank-a-holic's Avatar
skank-a-holic
should not be an issue!!
Old Mar 12, 2005 | 05:02 PM
Armitage's Avatar
Armitage
Yeah, I ordered the car only with the standard front dual airbags.
Thanks for the responses.
Old Mar 12, 2005 | 06:29 PM
mofoz's Avatar
mofoz
for those who did order seats with side air bags, you can buy the resistor that plugs into the car to turn the light off. you can get them from mynismo.com or z1performance.com
Old Mar 14, 2005 | 08:13 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
We sell the Airbag plugs for the sensors, but you only need these if you have the seats with the airbags.
Sounds like you don't need these, and you will have no worries at all swapping seats.
Old Mar 14, 2005 | 09:38 AM
hbenet's Avatar
hbenet
Tony,
If you have side airbags, swap the seats, but you add the NISMO Airbag warning removal; will the courtain airbags (the ones on the frames) still deploy???
Thanks.
Old Mar 14, 2005 | 12:02 PM
RedBird's Avatar
RedBird
Originally Posted by hbenet
Tony,
Thanks.
I would like to know also.
Old Mar 14, 2005 | 12:44 PM
hbenet's Avatar
hbenet
Tony, Jason, Performance?
Old Mar 14, 2005 | 12:47 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Also curious about that...I'm in this thread.
Old Mar 15, 2005 | 10:59 AM
hbenet's Avatar
hbenet
Ping!!
Old May 10, 2011 | 01:26 PM
vashuba311's Avatar
vashuba311
Im still looking at cars. Question is, if i get a car with cloth seats, can i swap the burnt orange in there without any modification( if they are heated/power?)
Old May 10, 2011 | 01:50 PM
VO...'s Avatar
VO...
Administrator
^^ Yes, you just won't have the heating option. The floor mounting points are identical...
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
SharX59
Sep 27, 2015 09:23 AM
