headlights fogging up from inside
Old Apr 6, 2005 | 06:23 AM
ricks350z's Avatar
ricks350z
Default headlights fogging up from inside
What's the deal here..my z is an 03..i was told to use a hairdryer and heat it up from the outside to see if this FOGGING OR SMUGGESS goes away...
btw, I did a search but it's not helping me at all.
Old Apr 6, 2005 | 07:24 AM
spdu4ia's Avatar
spdu4ia
take it to the dealer and get some new ones per warrante.
Old Apr 6, 2005 | 08:25 AM
SangWL's Avatar
SangWL
have you ever touched them before? for example, attempted to get the orange strip out? if not then they should be covered uner warranty.
sang
Old Apr 6, 2005 | 08:33 AM
ricks350z's Avatar
ricks350z
its out of warranty..car has 52 k on it ...everything is oem..never touched them at all or change strips, etc...
there's got to be an easier way to clean it then taking out the entire assembly and cleaning it from the inside..
Old Apr 6, 2005 | 09:38 AM
LaidbackRacr's Avatar
LaidbackRacr
Nope...if any consolation I had to replace mine, and lenses are not sold seperatly 1k through dealer for lens and housing 500 through misc chop shop. You can clean the inside though, this I know to be true (I did it) Good luck if you need pointers holla at me done it 4 times now.
Old Apr 6, 2005 | 10:00 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Not sure how long ago it started fogging up on you but when I first got my 03, it started fogging up about 6 months after. Brought it to the dealership & they told me that it was a known issue that some of the earlier model Z's had sealant problems with their headlights. In short, they simply replaced them under warrantee.
Old Apr 6, 2005 | 10:09 AM
old_s13's Avatar
old_s13
dealer has to evaluate the lights. all these newer-style encased headlamps have condensation issues, to a certain extent -- it really depends on where you live. this is common in areas with high humidity since moisture is in the air. however, if there is leakage.. then the light needs to be repaired/replaced.
you can always upgrade them to LED, we'll repair them when we reseal them! :-)
mike / clearcorners.com
Old Apr 6, 2005 | 10:38 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Sorry, don't mean to hijack but I needed to ask Mike a question since I have him on.
Hey Mike,
I'm thinking of getting a set of Super Black Headlights. I, however, want the clearstrip to be smoked w/ amber leds instead of the clear strip with white leds. Is this possible? How much would this be shipped? How long will it take? Please PM me details, thanks!
Okay...back on topic .
Old Apr 6, 2005 | 11:34 AM
Alonjar's Avatar
Alonjar
Take out the bulbs, like pull out the assembly thing and just leave it out so there is a hole in the housing.. then do the hair dryer trick.. or just leave the car so there is bright sunlight on the lights.. this should make the water evaporate, and hopefully escape through the bulb hole. It wont make it go away forever, but it should help get rid of all the trapped moisture.
Old Apr 6, 2005 | 03:33 PM
Edison_Chen's Avatar
Edison_Chen
When it was a bit colder outside, the 350Z had fogging in the headlamps. But not water droplets. Just regular fogging, and no modifications has been to done to the headlamps..
The told my dealer and they said, we have to take a look at them first and they would have to evaluate whether if it was necessary to replace them or not
Old Apr 6, 2005 | 05:07 PM
seanrulz's Avatar
seanrulz
I also had a headlight fogging/condensation problem and got them replaced at dealer under warranty. Since you said that you are out of warranty, new pair of headlight housings are going to cost you about $800~$900. Honestly, if you have to spend money anyway, I'd ship them to clearcorners.com and modify them. It won't cost you much more, and you'll have a pair of awesome headlights! The only downside is that you end up staying without your headlights for several weeks, so if your Z is a daily driver, it might not be a feasible option.
Old Apr 6, 2005 | 05:30 PM
LaidbackRacr
Well that isn't the only problem if like me you completely ruined yours there is nothing you can do but purchase new ones, but in your situation you can fix them yourself and if water gets in the HID i would recomend selling the car at that point because 2k for lights sux
Old Apr 6, 2005 | 05:55 PM
Monsta's Avatar
Monsta
See if someone would trade with you and take their Z to a dealer. Mine fogged up and they replaced it under warranty. Its obviously another defect on our cars. It may not affect all but it is on some. 52 miles or 52,000, it was there and its still there. So I don't see it as dishonesty.
UNLESS YOU HIT SOMETHIN
DUN DUN DUN (that music after the question WHO SHOT J.R.!!)
Old Apr 7, 2005 | 09:21 AM
old_s13's Avatar
old_s13
Originally Posted by GTNPU Z
Sorry, don't mean to hijack but I needed to ask Mike a I'm thinking of getting a set of Super Black Headlights. I, however, want the clearstrip to be smoked w/ amber leds instead of the clear strip with white leds. Is this possible? How much would this be shipped? How long will it take? Please PM me details, thanks!
I dont have private messaging turned on, so I'll just reply here..
Creating a smoked strip is not an issue, we've done in before and can do it again -- using amber LEDs is already an option, we offer that with our halogen headlamp conversion, applying that to the HID-spec headlamps is just preference. Downside is, attaining our product right now will be next to near impossible unless you are local in SoCal. Business will be closed for most of May, I am taking time off as I am getting married and will be travelling around parts of Europe. :-) April's work orders are almost up to the brim, so we're not taking any orders unless the customer is local or doesnt mind waiting till after May.
As for the headlamps, yeah.. I am sure you can swap with another 350Z owner who is under warranty, or you can just buy new ones, or used ones.. there are so many ways to resolve this issue. Or, if you have a spare car and some time.. you can go with our service. Or, you can attempt a DIY.. it really comes down to what you want to do. Its not a major issue, you just need to sort through your options. I just wanted to bring it to your attention that we can also assist.. rather than spending money on new headlamps.
Thanks guys!
Mike / ClearCorners.Com
Old Apr 7, 2005 | 09:44 AM
ricks350z's Avatar
ricks350z
Thanks guys!
Thanks for everyones' tip..I will make some decisions here.
Old Apr 7, 2005 | 09:53 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Thanks Mike. Guess I'll hit you guys up after May since I'm in no rush to get them right now. BTW...congrats with the wedding & have fun in Europe .
- James
Old Apr 11, 2005 | 08:35 AM
ricks350z's Avatar
ricks350z
Just curious, how much would it cost me to get 2 headlight cleaned out from the inside and have the orange bulbs all cleared out..im at zipcode 30066 in ga.?
Old Apr 12, 2005 | 05:18 AM
stu46's Avatar
stu46
I believe there's a TSB for this.
Old Apr 12, 2005 | 05:38 AM
ricks350z's Avatar
ricks350z
i check and theres tsb on it..maybe i overlooked it.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
3vilbunny
Jul 18, 2017 05:10 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
JGee450
Sep 30, 2015 04:32 AM
