HID install question
Old May 3, 2005 | 10:50 PM
tractng's Avatar
tractng
Default HID install question
Guys,
I am about to install aftermarket HID (H7 kit) for my base z. I saw a few threads where people took off their bumper to install the HID. Then other threads, people just remove the plastic part under the wheel well. I noticed with the installation through the wheel well, there isn't room on the passenger side.
Whats the best approach to install HID?
btw, how long is the install?
Tony
Old May 3, 2005 | 11:16 PM
yobri's Avatar
yobri
YMMV, but unless your wiring is all prepped as per OEM spec, I'd take out the headlamps to ensure that you're doing things right, i.e. mounting the ballast, snaking the wires in and ensuring that the cover is clamped down tight and proper, etc. You might have to drill into the cover to get the wiring through also. Although it would take a bit more time, I think that the job will be easier with the headlamp out of the car.
If you had an OEM HID set already in your car, then going through the wheel well would easily be recommended for bulb changes (for it's sheer simplicity). If you want to shortcut it, try the wheel well method. If you find that it doesn't work well for you, you know what to do next Good luck!
Old May 4, 2005 | 11:20 AM
Jun's Avatar
Jun
Best approach is to remove the bumper. It should take you about 10 minutes max. Doesn't sound like to much time if you want to get something done right.
Old May 4, 2005 | 03:20 PM
tractng's Avatar
tractng
June,
Do you have to remove the wheels? Also, how big is the oem ballast? Just trying to compare with the aftermarket ballast to see if it fits in that location
Tony
Old May 4, 2005 | 03:25 PM
yobri's Avatar
yobri
Originally Posted by tractng
June,
Tony
To do what he described, no (I learned how to do the install from Jun). What aftermarket kit do you have?
Old May 4, 2005 | 04:43 PM
Jun's Avatar
Jun
June,
Tony
Tonye:
No need to remove the wheel. Just turn the wheel one way to access the bolts on one side, and repeat on the other side.
Aftermarket ballast won't fit in the OEM location because of 1) shape and 2) size.
Jun
Workshop12
Mar 23, 2020 01:45 PM
TrackFiddy
Sep 24, 2015 11:40 PM
Suffolk350z
Sep 13, 2015 02:43 PM
