For those who installed JDM style Nismo Wing?
Sorry, if this has been asked before.
I just got a JDM style Nismo wing (Carbon Fiber) and I'm going to
get it painted and installed. The quality is very good.
Unfortunately, there was no instruction about how to install.
Does anyone have a instruction or any advise about installation?
Thank you for any helps.
LUCK
LUCK
If you have no OEM wing right now it's as simple as drilling 4 holes and using double sided tape around the entire outside edge of the bottom of the wing (carefully positioned so that it doesn't show after the wing is tightened down. If you have an OEM wing (track model for example) then you have the problem of removing that wing and taking more care to cover the holed left after removal.
What are your plans for painting it ? Leaving any CF showing ?
Yes, I leave a bottom center piece carbon fiber, the rest will get painted
Silverstone. Thank you.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
