Voodoo Spun Shift Knob with custom neck
Old Jun 8, 2005 | 05:54 PM
copba1t's Avatar
copba1t
Thumbs up Voodoo Spun Shift **** with custom neck
Parts:
Team Voodoo Spun Aluminum **** $31
Plastic Leg Tips: $1.99
Door Bumper: $1.29
I wanted a shorter shift **** to decrease the throw a little more and also wanted a round **** which are more comfortable in my hand. I went with the Voodoo spun aluminum ****, which were created for the Miatas but have become very popular for other cars as well. It was really cheap at only $31 and the other parts were next to nothing at the local hardware store so overall it was a pretty cheap mod at under $40.
I started out by removing the plastic retainer piece on the original shift boot and trimming the boot down to remove excess material, as the new **** would be lower and require less boot. Sewed the top of the boot back up nice and tight so it was snug against the shaft.
I then cut the rubber bumper in half to remove the larger end because all I wanted was the smaller cylinder end which will serve as a foundation for the leg tip. I had to bore out the center hole of the bumper a bit to get it to slide onto the shaft which it did nicely. They I drilled out the closed end of the leg tip so it would also slide onto the shaft, and fit that down over the rubber bumper I had just installed. Next I just screwed on the shift **** and that was basically it. I did have to cut the leg tip down a bit because it was too tall.
Here is a pic of the parts:
Here is a closeup of the **** installed:
Here is one from a distance:
Another:
The leg tip is the same exact diameter and fits flush with the **** bottom so it feels very smooth and comfortable while shifting. Granted this is just a cheap and ugly hack of a job, but hey I think it looks halfway decent, definitely better than those rubber toilet gasket things I read some people were using, lol.
Old Jun 8, 2005 | 05:59 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Looks good, nice job.
Old Jun 8, 2005 | 07:47 PM
Z BOY's Avatar
Z BOY
so you finally came around. i have the pearl magnum, and i'll say it again: i believe the voodoo magnum **** is the best **** for our cars. i like your finisher idea. thanx for sharing.
Old Jun 8, 2005 | 08:33 PM
copba1t's Avatar
copba1t
Yea either of those two look awesome with our interiors. I have actually had mine for a few months but have just been slacking at coming up with a decent sleeve/neck solution so I held off. Good choice bro =)
Old Jun 8, 2005 | 08:34 PM
xziteme's Avatar
xziteme
Pretty good work on the ****!
I, too, went w/ Voodoo but opted for the regular size w/ collar. I love it! No rattles!
Old Jun 9, 2005 | 12:00 AM
copba1t's Avatar
copba1t
Nice! I like that even better. Did you order the collar from Voodoo as well?
Old Jun 9, 2005 | 06:23 AM
xziteme's Avatar
xziteme
The collar was through Voodoo, but I think it only fits the regular size (not the Magnum).
Old Jun 13, 2005 | 04:19 PM
copba1t's Avatar
copba1t
Even though I liked the shorter shaft length at first, it was a bit too short as my hand was rubbing the boot too much, so I just added a spacer to raise the **** up a bit, and I think I like the look even better...
Old Jun 14, 2005 | 06:55 PM
supra crazy's Avatar
supra crazy
i went to the link posted and it seems they dont sell it on there site. where did you guys purchase the ***** from?
Old Jun 14, 2005 | 10:23 PM
copba1t's Avatar
copba1t
The link I gave in the first post works for me, you can get to the pricing and application chart from there.
Old Jun 15, 2005 | 10:16 AM
Zmeflyby's Avatar
Zmeflyby
looks nice and shiney
Old Jun 15, 2005 | 07:42 PM
05-Z's Avatar
05-Z
I have one in my Honda, and these are best ***** out there. Easily. I just got one for the Z and a new shift boot from Redline, I'll install them this weekend and post pics.
Old Dec 21, 2005 | 05:46 PM
Amiricanmade's Avatar
Amiricanmade
Is this shift-**** similar to the ARC titanium? Does this one sit a little higher than the ARC?
Old Feb 17, 2006 | 11:17 PM
Amiricanmade
+1...where can i buy it? and can i get it with out the spacer? i like the LOW feeling.
Old Feb 18, 2006 | 06:55 AM
angelz's Avatar
angelz
http://www.teamvoodoo.com/index.htm
Old Feb 20, 2006 | 03:27 PM
Amiricanmade
Originally Posted by angelz
Thanks.
Anyone know if i get Spun aluminum, Polished aluminum, orPearl aluminum to match my car?(the silver stuff in the z.
Old Feb 25, 2006 | 05:16 PM
Amiricanmade
Thanks.
.........yellow?
sherm
Apr 11, 2020 05:21 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
