New Xenon Interior/Exterior Lights
Old Jun 20, 2005 | 05:27 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Thanks for the education!
Old Jun 21, 2005 | 12:38 PM
tlewis's Avatar
tlewis
I got mine in today and installed them... I got both the Xenon interior and silver turn signals. Total install took about 20 mins.
I could definatley tell that these bulbs are not as bright as the originals... I could barely see the turn signals in the daylight. I'll have to check out the difference at night and post the results...
Old Jun 21, 2005 | 01:17 PM
Slanteye's Avatar
Slanteye
yeah I received my interiors today but can't install because the Z is @ the dealer
Old Aug 17, 2005 | 03:16 PM
ws350's Avatar
ws350
Originally Posted by Paul350Z
www.superbrightLEDs.com
www.autolumination.com
The four LED bulb fits perfectly. I've got a pair of 6 LED ones on order from AutoLumination to see if they'll fit.
Are you referring to the 6 LED ones shown on the top of this page: http://autolumination.com/festoon.htm ?
How did they fit and look? Thanks!
Old Aug 17, 2005 | 06:03 PM
momo 350z's Avatar
momo 350z
im def going to buy the feston as shown here--->
Old Aug 17, 2005 | 09:04 PM
Tekwon-V's Avatar
Tekwon-V
i just replaced my dome lights too. i got the 7 color roating LED bulbs from autozone. the bulb rotates 7 LED colors. red, blue, green, and other colors that i cant remember lol. it gradually changes to the next color.
i wanted the 2 bulbs to rotate colors together but it doesnt. i just wanted to spiffen up the interrior a little bit so it doesnt really matter. just fo' sho', you heard lol.
Old Aug 17, 2005 | 09:58 PM
trescincuenta's Avatar
trescincuenta
Originally Posted by Netko350Z
There was a post where this guy did FULL leds for every outside bulb. He went through superbrightleds.com.
He even changed out the LED for the front turn signals. No more ugly yellow bulb!!!
I found the list he posted. I printed off what he ordered:
(2) WLED-6-LED Bulb (red)-rear parking lights
(4) WLED-6-LED Bulb (white)-2 for front parking and 2 for rear license
(2) 7443-15 LED Blub (red)-brake/tail lights
(4) 7440-15 LED Bulb (amber)-front and rear turn signals
(2) 7440-15 LED Bulb (white)-reverse lights
Total cost was $85.46 with shipping
The only thing that I didn't see on his list was for the front side markers.
Yup that was me. I ordered the festoon bulbs from there too, but afterwards, so whats why they aren't on that list. The 4 LED ones work fantastic. Give off a bright light with a bluish hue thats very bright and look alot "cooler" than the factory bulb. Only drawback is you lose the slow fade to off when you lock the doors. They just fade for a split second then just shut off completely.
Also you don't see an application for the front side markers because they dont use bulbs LoL they are just reflectors.
Dr Bonz, I definitely recommend the LED's I got for yoru license plate lights too. Can we say bright?!?? You can see my Miami heat plate at night from quite a distance!
The only bulbs I changed to LED that I regret (and as a matter of fact tomorrow im putting the stock bulbs back in) are the brake/tail light bulb. The factory bulb is a dual filament bright/low for brake/taillight. It sits in the factory housing pointing straight up. This causes a huge problem cause LED bulbs are directional. Also the other major porblem, which is the biggest one, is that the difference between tail and brake light operation is very minimal. When you press the brakes the brake lights only get slightly brighter. At night its not such a big a deal but during the day the difference is almost imperceptible. You can tell im braking mostly because of the 3rd brakelight lighting up and not because of the brightness difference on the brake lights themselves.
If anyone has any questions feel free to ask them here or PM me.
Old Aug 18, 2005 | 06:01 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Have a look at these instead.
$7 each x 2
I bought one of these for $20 and I'm going to see if I can get it to fit inside the dome light.
Old Aug 18, 2005 | 09:28 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Originally Posted by TiPIACE
.... need something in the order of 20000volts to ignite xenon gas within a true xenon globe, so unless all those little globes come with ballasts and ignitors, im afraid theyre a product of misinformed marketing
I had bulbs from the vision GB and they were clearly not xenon. They were white and about half as bright as stock so they have been removed. I am also not arguing the over marketing and outright lying of lots of companies as to the type of bulbs they are selling.
But, there are filament bulbs with Xenon gas in them that are brighter than halogen and don't need 20000 volts to fire. I have had an underwater flashlight for years that is blighter than halogens of the same wattage using the same batteries, very white and does not have any kind of blue coating on the bulb. What the HIDs do and why they need a ballast to start is they don't use a filament, the ballast is used to get the arc started access an open gap and once on, the electricity continues to flow and produce light. If you have a fillement, you don't need the arc.
LED dome bulbs Pros and Cons
The 6 LED type are bright, real bright but you loose the fade out of the incandescent bulbs so it comes on hard and goes off hard. Also, on mine anyway, when it's dark out I notice that they sometimes glow real faint. They are coming out soon.
So far I have not found dome light bulbs I like better than stock.
Chris
Old Aug 21, 2005 | 08:04 PM
jdpdata's Avatar
jdpdata
I thinking about getting 7440-15 LED bulbs (amber)-front and rear turn signals. Do I need to get the load resistor kit? The LEDs are not going to blink super fast are they?
Old Aug 21, 2005 | 08:24 PM
iceman21_23's Avatar
iceman21_23
do you guys know what fuse contorls the interior lights ala dome and hatch light?
Old Nov 15, 2005 | 08:56 AM
Silver350NY's Avatar
Silver350NY
Are the dome lights 44mm?
Old Apr 26, 2007 | 04:02 PM
350ZIvy's Avatar
350ZIvy
It is better to get LED bulbs.
http://stores.ebay.com/MotoringMax
Old May 1, 2007 | 07:47 AM
RedBullRR's Avatar
RedBullRR
What size are the Bulbs on the Dome Lights and the Bulbs for the License Plate? I want to order these I love these led lights. My Ex has it on her Lexus from the dealer and they look incredible.
Old Aug 24, 2007 | 10:25 PM
SolarOrangeZ's Avatar
SolarOrangeZ
yeah...size please.
Old Aug 26, 2007 | 09:49 PM
UrbanTacticZ's Avatar
UrbanTacticZ
License plate bulbs size: 168
http://www.superbrightleds.com/mini-wedge.html
Chart to match your regular bulbs to the new LED ones:
http://superbrightleds.com/bulb_cross.htm
Website that shows all your bulb sizes:
http://www.sylvania.com/ConsumerProd...lacementGuide/
Old Aug 26, 2007 | 10:13 PM
SolarOrangeZ
Thanks Prashant, how about the dome lights for the 2007. Any idea on the size? Thanks
Old Aug 27, 2007 | 11:54 AM
  #38
UrbanTacticZ
Good question, it's not on that page from my previous link that tells you bulb sizes for all the cars.
Take it to an Autozone/Kragen/Napa Auto Parts, and match it up or ask the person behind the counter.
I just purchased 5 of those LED bulbs last night. 2 for the license plate, 2 for the parking lights (in the headlights), 1 for the cargo area in the hatch (the stock bulb SUCKS). I hope those 5 LED, star pattern, fit into the assemblies I chose the 5 LED, star pattern, because of their wide, 180degree, light angle. I will post more info when I get them!
Old Aug 30, 2007 | 09:36 PM
  #39
xxbrokkxx's Avatar
xxbrokkxx
+809471263984561
Old Aug 30, 2007 | 09:49 PM
  #40
usmanasif's Avatar
usmanasif
Doc (don't think you come here anymore though), xenon bulbs are filled with xenon gas and don't come in non-headlight applications. These here create a white-ish light simply by filtering light through a blue housing.
Captain obvious strikes again!
