MOMO auto shift knob install/mod
Old Jun 23, 2005 | 06:27 PM
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
Default MOMO auto shift **** install/mod
Installed the MOMO auto shift **** and found the directions weren't much help. Also found the adapters included weren't up to snuff for my 2k5 Z. As a workaround... picked up two nylon spacers from Home Depot for < $1. One spacer placed on the tip of the green rod (after removing stock ****) and another at the base of the MOMO ****.
First the smaller nylon spacer was inserted into the MOMO ****. The spacer diameter was chosen just less than the diamter of the MOMO **** chamber to allow it to move freely. Second a larger nylon spacer was placed at the base of the MOMO ****. A little filing and I was able to hammer the spacer in place for a tight fit at the base. Installed the **** as normal.
Benefits are a far more stable **** since the two spacers eliminate most movement during installation and the allen key tightening screws actually tighten against the spacer rather than into the metal of the shifter rod for a superior fit. No more scratching the rod just to get the MOMO **** tightened.
Just a suggestion if anyone has or is purchasing a MOMO automatic shift ****.
ROGUELITE
Old Jun 23, 2005 | 10:47 PM
B-Unit's Avatar
B-Unit
Post some pics man, this is one of those topics you gotta post pics on.
Old Feb 1, 2006 | 04:41 PM
alex12's Avatar
alex12
+1 on pics. If you don't have them avalible, did you get the leather or aluminum model?
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
