Light-Up Clear Reflectors for Front Bumper - Still Being Made?
Old Jul 13, 2005 | 11:25 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Default Light-Up Clear Reflectors for Front Bumper - Still Being Made?
Is anyone still making / selling the clear reflectors with hyperwhite LEDs?
If so, how difficult is the install (how/where do you splice into the power supply)?
Old Jul 14, 2005 | 06:33 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Yes, they're still being made - clearcorners.com sells them amoung a couple of others.
To splice them in you'll need the blue 3M slicers - you can connect them to the parking or turn indicator lights pretty simply.
Old Jul 14, 2005 | 08:58 AM
ares's Avatar
ares
Veteran
hello. Im still around despite a gimp website.
paul has the install info right. just tap into the wires coming out of the headlight.
Old Jul 14, 2005 | 03:37 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Ares, you have pm.
Old Jul 14, 2005 | 03:42 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Ares,
Since you have a "gimp" website , may I suggest creating a Photobucket account & post pictures of your products. You can also use the picture description field to insert the name of the product & pricing. Then link it on your sig. This is what Bat did when his site went down & it has worked really well for him. Just a suggestion but I think this would increase your sales .
Old Jul 14, 2005 | 04:12 PM
Roger V's Avatar
Roger V
Ares makes a great product. I will post pics of the ones I bought from him tonight after the meet.
Old Jul 14, 2005 | 04:30 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Do you need to install resistors with the LEDs...
1) with parking lights?
2) with turn signals?
Old Jul 14, 2005 | 09:41 PM
ares's Avatar
ares
Veteran
neither. the resistors for the LEDs atleast with mine are in the reflector unit. as for the resistors you see sold for turn signals and whatnot, not nescessary either. these are just piggybacking off the existing circuit.
Old Jul 15, 2005 | 08:05 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I think he means the big 5W ones to prevent/cure "hyper-blink" where the blink rate goes from like 20 a minute to like 100 blinks per minute.
LED's don't draw a whole bunch of power. The turn signal circuits sense that their normal 8 watt load is now gone down to just a watt or two so they "think" that something is wrong - like a blown out light bulb - so for safety's sake they hyper-blink to alert you. I drove around for a couple of weeks with mine blinking that fast and didn't like it so I went with the load resistors.
You do NOT put them in the parking light circuits - only the turn signals. One 4 ohm resistor will go on each side which will work for both the front and back, left and right.
If you're only swapping out the fronts (or rears for that matter) you'll need an 8 ohm resistor.
Beware that these guys heat up like a son-of-a-gun. I put my hazzards on for about 15 minutes and the things became too hot to handle so make sure you mount them away from wires and plastic. I attached mine in the front and wire tied thier wires in place to hold it to a small 1" square metal tube that was just next to the headlights.
Old Jul 15, 2005 | 08:57 AM
ares's Avatar
ares
Veteran
but if your doing reflectors; and your stock bulbs remain; your bulbs are all the resistance you need. you just need 1 high wattage draw on the line; either a bulb or one of those resistors. the reflectors would never replace the bulb(atleast I hope not lol) so these are just an extra item and wont be affected.
if you go with LED turn signal bulbs; then you would get into that arena.
and also; my website works now well atleast with all the photos I have.
Old Jul 15, 2005 | 04:23 PM
Yuichi's Avatar
Yuichi
Ares does good work I'm happy with mine
Old Jul 15, 2005 | 07:28 PM
Netko350Z's Avatar
Netko350Z
Prices?
for the reflectors. Both the 3 LED and 30?
PM ME!
TYVM!
Old Jul 18, 2005 | 10:37 AM
HockeyZ39's Avatar
HockeyZ39
I would also like a price on the clear 30 LED reflector. Thanks!
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
