need help with wiring?
Old Jul 21, 2005 | 08:19 PM
vaderzo6's Avatar
vaderzo6
Default need help with wiring?
installing 2 gauges, apparently from what im hearing behind the stock a-pillar theres power(ignition), ground, and constant power. what im looking for is where to tap into the car for when at night the gauges come on with the lights on the dash(parking lights, or full headlights on) a location would be excellent and what color wire it is? i know on mitsubishi if you find a green with white stripe its lighting. or if there is a write up somwhere it would be appreciative. thanks a lot guys.
Old Jul 22, 2005 | 12:34 PM
mandm177's Avatar
mandm177
tap into the dimmer wire behind the radio...not exactly sure wat color it is though
Old Jul 24, 2005 | 07:35 AM
voodoo's Avatar
voodoo
or you can run a long wire all the way from the headlight itself [from the wheel well]
i'm installing 2 gauges as well. can you tell me where to tap power & ignition from behind the A pillar???
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
