"How to" Question?
Old Jul 28, 2005 | 05:04 PM
Solrac's Avatar
Solrac
Default "How to" Question?
I've tried searching forums and I can't seem to find a detailed step by step instruction on how to get to the reverse lights. It looks like my car came with a loose, right, reverse fixture from the dealership, and they dont want to fix it. I think it may just not have been screwed in properly from the factory so I don't think it would be too hard to fix. If someone could help me get to it from the inside so that i could add the missing screw, that would be great. Any help would be appreciated.
Old Jul 28, 2005 | 07:59 PM
Solrac's Avatar
Solrac
The link provided doesnt seem to work...
Old Jul 28, 2005 | 08:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Take off the tail light housings... you will need a 10mm ratchet.
Old Jul 28, 2005 | 09:07 PM
Solrac's Avatar
Solrac
How do i get to the bolts that tighten the housings?? I'm guessing I have to remove some part in the trunk, but I just want to make sure i know which part i need to remove to get to them
Old Jul 29, 2005 | 01:39 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
There are some plastic covers over the bolts. Flip them out with a flat head screwdriver.
Use the ratchet to undo the bolts...
once all 3 bolts are out, pull the tail lights LATERALLY... that is, if you're on the RIGHT side of the car, pull the tail light to the RIGHT. (not backward)
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
