Headlights
Old Aug 26, 2005 | 04:32 PM
black_03's Avatar
black_03
Default Headlights
I have an 03' base and just bought some brighter headlights what is the easiest way to install the light bulbs i have both low/high beams please help thanks
Old Aug 26, 2005 | 04:49 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
First of all, if you just bought bulbs and not some kind of HID conversion kit, your bulbs probably won't be any brighter unless you went to a higher wattage.
Higher wattage can fry your wiring... not a good idea.
If it's just some aftermarket bulb that's the correct wattage, it may be a little bit whiter in appearance due to the blue tint of the bulb, which filters out yellow. (It will probably not be any brighter though)
Basically you have to take off the front wheel, unscrew a few key places on the fender liner, then peel back the liner. You will see a white disc-shaped thing... unscrew it and you will have full access to your headlights.
If you search the forums, you will find more info.
Old Aug 26, 2005 | 05:43 PM
zYouLater's Avatar
zYouLater
Send the bulbs back and wait for the 2006 headlights. They are the hottest and I'm sure everyone will be going after those.
Good Luck!
Old Aug 26, 2005 | 07:15 PM
black_03's Avatar
black_03
whats going to be so special about the 06' headlights? The bulbs are a higher wattage hopefully nothin will happin to the wiring.....should i have gone with an HID Kit any good prices on any? thanks for the help....
Old Aug 27, 2005 | 09:35 AM
old_s13's Avatar
old_s13
Incorrect, high-output bulbs can emit 50% more light without consuming more current.
- Mike
Old Aug 29, 2005 | 01:54 PM
MY350Z.COM's Avatar
HID conversion kits make a world of a differance.
Old Aug 29, 2005 | 06:07 PM
mickey99us's Avatar
mickey99us
ok so what would be a simple conversion and how easy would it be to install
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
