my latest mod - billet
Old Dec 18, 2002 | 12:33 PM
MELRUMMY's Avatar
MELRUMMY
Default Billet
If you guys' are buiding, I'm Buying !
Keep on Z'n Still Jumpin' for Joy at 6500 Miles
Old Dec 24, 2002 | 11:37 AM
tknocks's Avatar
tknocks
Default billet
I'll buy, too....
Old Dec 25, 2002 | 01:37 AM
roberto350z's Avatar
roberto350z
customer aqui....that plate is bad ***!
Old Dec 25, 2002 | 06:00 AM
wadd3456's Avatar
wadd3456
If you like the plate, Im accepting orders now.
Prolly cut them around the 3-5th.
Old Dec 25, 2002 | 07:19 AM
MSOsr's Avatar
MSOsr
Does the plate need to be polished occasionally, or is it coated or stainless?
Old Dec 25, 2002 | 11:41 AM
N74DV's Avatar
N74DV
mine is cut from 2024 Aluminum. I should have made it from 6061 caus ethe 2024 needs some form of coating. I'll have it clear anodized soon.
I suspect Wadd will make them from stainless and/or 6061 Aluminum.
Old Dec 25, 2002 | 12:40 PM
Zrated's Avatar
Zrated
Thumbs up
VERY sweet! Looks like a must for anyone who plans on doing shows. Excellent work!
Old Dec 25, 2002 | 01:33 PM
wadd3456's Avatar
wadd3456
Yeah 6061 or stainless is what I will most likely use.
Old Dec 27, 2002 | 10:59 PM
daveggetsaz's Avatar
daveggetsaz
looks sweet! whats the cost wadd and how hard will the install be?
Old Dec 28, 2002 | 06:02 AM
N74DV's Avatar
N74DV
I'm not sure what he's charging... I think $60, but as the designer of the piece, I can tell you the install takes about 5 minutes.
Just pop the 6 plastic bumper clips... put the piece on the front end... and push the clips back down. then you need to put some clear rubber bumper thingies (used on cabinet doors) on two areas on the under side of the hood where the hood slightly touches the aluminum piece.
thats it....
Old Jan 1, 2003 | 06:54 PM
shagz's Avatar
shagz
Is it possible to extend the plate, contour it and cover up the cheapo plastic cover on top of the radiator? It'll probably require more sophisticated hardware to mold it.
Old Jan 1, 2003 | 07:23 PM
N74DV's Avatar
N74DV
I had considered that.... it could be done but would require the aluminum piece to be stamped with a die the same shape as the radiator... tooling for this would be spendy...
I'd say it would only be cost effective if over 5,000 would be made. may take awhile to sell that many right now
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
