D.I.Y Getting to the Headlight Area
Old Nov 15, 2005 | 08:21 PM
ZlleH's Avatar
ZlleH
Default D.I.Y Getting to the Headlight Area
So I was really bored since my car is hibernating for the winter now.
Note: I'm in no way responsible if you damage your car, Attempt this at your own risk.
Here is what you will need(notice the blantent attempt at showing off my work-in-progress plastic Model):
Old Nov 15, 2005 | 08:22 PM
ZlleH's Avatar
ZlleH
Jack up the car and remove the wheel:
cessna's Avatar
cessna
Damn it Young....
Come flying with me!!!! I let you have the controls at 160 miles per hour!!! I'm sure you'll like that!!!
Seriously, anytime this week/week-end works for me!
Regards,
Louis
Old Nov 15, 2005 | 08:23 PM
ZlleH's Avatar
ZlleH
Unscrew these two screws:
Old Nov 15, 2005 | 08:24 PM
ZlleH's Avatar
ZlleH
Take these three um... whatchamacallits out(will show in details later).
Old Nov 15, 2005 | 08:25 PM
ZlleH's Avatar
ZlleH
Unbolt these two bolts(ignore the scrapage )
Old Nov 15, 2005 | 08:27 PM
ZlleH's Avatar
ZlleH
Here is an attempt at showing you how to take out the whatyamacallits:
Attached Thumbnails D.I.Y Getting to the Headlight Area-headlight06.jpg   D.I.Y Getting to the Headlight Area-headlight07.jpg   D.I.Y Getting to the Headlight Area-headlight08.jpg
Old Nov 15, 2005 | 08:28 PM
ZlleH's Avatar
ZlleH
Put your hands underneath the rear flap and grab the front flap and pull it out:
Attached Thumbnails D.I.Y Getting to the Headlight Area-headlight09.jpg   D.I.Y Getting to the Headlight Area-headlight10.jpg
Old Nov 15, 2005 | 08:29 PM
ZlleH's Avatar
ZlleH
Also pull out the bottom area of the front flap:
Old Nov 15, 2005 | 08:31 PM
ZlleH's Avatar
ZlleH
Now you will have plenty of room to work:
Attached Thumbnails D.I.Y Getting to the Headlight Area-headlight12.jpg   D.I.Y Getting to the Headlight Area-headlight13.jpg
cessna's Avatar
cessna
Originally Posted by cessna
Damn it Young....
Regards,
Louis
Young you look deperate!!! Give me a call brother!
Old Nov 15, 2005 | 08:33 PM
ZlleH's Avatar
ZlleH
Default In Addition: Changing the Turn Signal bulb
I was changing the turn signal bulb when I decided to do this D.I.Y so here it is:
Old Nov 15, 2005 | 08:36 PM
ZlleH's Avatar
ZlleH
It might seem tight and you might be scared to break the bulb, but it will come off. Just don't snap it in a quick and forceful manner. Gently wiggle the bulb side to side while pulling outwards:
Attached Thumbnails D.I.Y Getting to the Headlight Area-headlight15.jpg   D.I.Y Getting to the Headlight Area-headlight16.jpg
Old Nov 15, 2005 | 08:39 PM
ZlleH's Avatar
ZlleH
Hope this helps anyone to be more confident that they can change the Turning signal by themselves.
Hopefully I can update this thread when my Hyper White H7 day running light comes. I'll also do one for the parking lights.
If I forgot anything, please don't hesitate to correct me.
PS: Someone said you can do this without jacking the car up and removing the tires by just turning the wheels inwards. I tried that and the space was nearly impossible to work with.
Vamos_Rafael's Avatar
Vamos_Rafael
u should of replaced it with a clear bulb..
for a DTM look
Old Nov 15, 2005 | 08:45 PM
ZlleH's Avatar
ZlleH
I wasn't going to post these last pics just in case some people just want to change out a burnt bulb with OEM bulbs.
Plus, these clear LED amber one that I installed blinks too quickly, you need some kind of registers to make it blink normally.
Second picture is with clear LED that turns amber when blinking. The third picture is the before picture with the orange OEM bulb.
Attached Thumbnails D.I.Y Getting to the Headlight Area-headlight17.jpg   D.I.Y Getting to the Headlight Area-headlight18.jpg   D.I.Y Getting to the Headlight Area-dscn1403s.jpg
Old Nov 18, 2005 | 08:35 PM
ZlleH's Avatar
ZlleH
Just recieved my $0.50 Ebay Hyper White H7($0.01 if you wait out the 24 hour bidding):
Old Nov 18, 2005 | 08:38 PM
ZlleH's Avatar
ZlleH
What you will need other then the three tools I posted at the beginning:
Latex glove(don't ask me why I happen to have one handy...):
Old Nov 18, 2005 | 08:43 PM
ZlleH's Avatar
ZlleH
After you have taken the white cap off to expose the HID and H7 area as shown on post 12, this is what you will see:
Old Nov 18, 2005 | 08:56 PM
ZlleH's Avatar
ZlleH
At first, the H7 area looks a little scary and complicated. But once you find out how to open it to get to the bulb, you will be amazed how easy it is.
Here is a close up picture of the H7 area. Instruction is pasted on the picture:
