HID Cutoff MOD?
Old Oct 4, 2007 | 10:31 PM
redlude97's Avatar
redlude97
I still think I have you beat, remember the rainbow I had?
Old Oct 4, 2007 | 10:39 PM
Ivory's Avatar
Ivory
LOL, you right. I think the rainbow is from the bottom of the cutoff ring reflecting on top because the lack of foreground shield.
Old Oct 4, 2007 | 10:41 PM
redlude97's Avatar
redlude97
You mean the spacer or the actual foreground shield? I hadn't dremeled out the foreground limiter at that point.
Old Oct 4, 2007 | 11:38 PM
Ivory's Avatar
Ivory
wow really? then I don't know how you had gotten the rainbow...cuz I didnt see anything of the sort until i dremeled the foreground.
Old Oct 5, 2007 | 12:17 AM
usmanasif's Avatar
usmanasif
how much of the color spectrum do you figure is in this?
Phenomenal! Very nicely done. I don't recall seeing this particular pic on HID Planet; did you post it there? I may have missed it.
Old Oct 5, 2007 | 05:18 AM
Ivory's Avatar
Ivory
yeah it was among one of the various colormodded light threads...usually gotten iqnored quickly. haha.
Old Oct 7, 2007 | 01:22 AM
Accordaleer's Avatar
Accordaleer
1. Why does that pic look like you had your car in your living room lol, and 2, whats up with the light on our right hand side... is that with or without lense mod cuz that light doesnt look usable.
Old Oct 7, 2007 | 01:42 AM
Ghost_shift's Avatar
Ghost_shift
My car came with OEM HID headlight system, why do I care about your products?
US car dealerships (foreign & US brands) are allowed to sell HID capsules in 4,000K range only.
So swap your existing OEM capsules (4,000K) with our 5,000K model for a slightly bluer tone. Our D2S & D2R capsules pop right into your Headlight housing. No additional ballasts or wiring are needed. And ours cost only a fraction of what the dealer charges you.
Speaking of this Kelvin temperature (K), is higher the better?
Not at all. Higher is actually purpler and dimmer.
We don't recommend using capsules with temperature higher than 6,000K. For show use, you may opt for 8,000K or 10,000K capsules.
Color TemperatureLumen (±7%)4,100 K3,000 lm5,000 K2,700 lm6,000 K2,600 lm8,000 K2,000 lm
Tell me more about Color Temperature (K)?
Color Temperature is a measurement in Degrees Kelvin that indicates the hue of a specific type of light source. Many people believe the misconception that color temperature is a rating of the brightness of the bulb or HID kit. This belief is completely false. The reality of the matter is that the higher the color temperature, the less useable light output you will obtain. A perfect example would be a black light. This light has a color temperature of approx 12,000k and has almost no useable light or lumens output.
As the color temperature increases, the color of the light moves from yellow -> white -> blue-white. HID headlights provide light at a higher color temperature than standard halogen headlights, which gives them a crisp white appearance. HID lamps come in 4300K, 5000K, 6000K, 8000K, 10000K, 12000K or 14000K. The difference is the coloring from white through blue to purple. As a reference, sunlight at noon is 5250°K. You'll want to make yourself familiar with the different hues to make your choice. Higher color temperature doesn't mean brighter. As a matter of fact, higher K Kits, such as 10,000K, 12000K and 14000K, have been manufactured for individuals that are more concerned about the actual color output as opposed to the actual useable light output.
What can I do to prolong the lifespan of my HID capsules?
Glad that you asked. HID capsules are very delicate & fragile components indeed.
Old Oct 7, 2007 | 01:43 AM
Ghost_shift
More for your reading pleasure....
http://www.hidsrus.com/FAQ.html
http://www.coolbulbs.com/HID_faq.asp
Old Oct 7, 2007 | 01:48 AM
___DJK___'s Avatar
___DJK___
Driver side headlamp is typically aimed a little lower than the passenger side (to avoid blinding oncoming traffic).
Old Oct 7, 2007 | 02:35 AM
Accordaleer
pretty sure mine are equal. The drivers side light is almost useless.
Old Oct 7, 2007 | 10:48 AM
Ivory's Avatar
Ivory
it' in ___/---/---- shape
so you get most use-able light on your lane while not blinding the traffic.
so yes it's useless because there isn't suppose to be light in that area.
Old Oct 7, 2007 | 10:49 AM
Ivory's Avatar
Ivory
You don't need to aim them lower, that's what cutoff is for. they are aimmed at the same height.
Old Oct 7, 2007 | 01:22 PM
Accordaleer
I would do this mod,never noticed they are aimed that differenty that much. never once noticed my driver side being aimed downward that hardcore. So what is the process that you do actually, crack em open and take the lenses out and replace them? Just curious as to what my 6k would look like since 4300 look like that.
Old Oct 7, 2007 | 02:26 PM
redlude97's Avatar
redlude97
You still don't get it, the driver's side isn't aimed any differently than the passenger side, they are aimed to the same level. The cutoff has a step in it, which is what you are seeing in Ivory's pictures
Old Oct 7, 2007 | 02:46 PM
Ivory's Avatar
Ivory
does this make more sense? they both have the same notch "cutoff"
Old Oct 7, 2007 | 07:48 PM
Accordaleer
Jesus Christ, everyone is so ready to jump on each other. Sorry i only went by what someone else said..... hence the reason i asked.... Looks good Ivory
Old Oct 7, 2007 | 07:52 PM
  #38
jtabraham's Avatar
jtabraham
Did you drive through your living room?
Old Oct 7, 2007 | 08:35 PM
  #39
redlude97's Avatar
redlude97
Yep, my garage and living room are connected so I always know my G is okay
Old Oct 7, 2007 | 08:42 PM
  #40
Ivory's Avatar
Ivory
hah...he drove through the garage and into the living room, breaking one of the lights...that's why there is only 1 cutoff..
