Led for those who has customized using leds
Old Dec 11, 2005 | 09:22 PM
Daytona350Texas's Avatar
Daytona350Texas
Originally Posted by ares
I may be wrong about how your describing it. but heres how it should be.
positivewire-LED-LED-LED-resistor-negativewire.
now what you can do, is something like this
LED-LED-LED
Positivewire< >resistor-negative wire
LED-LED-LED
so now you have 1 positive wire, 1 resistor, and 1 negative wire. but you split the LED series. the leds will go positive-tall short-tall short-tall short-resistor
you cant have more than 3 LEDs in a series for white(4 can be done but its not great for the LEDs because the current varies)
take the above setup and imagine the LED-LED-LED many times, each set of 3 its own thing, all connected on 1 side to the positive wire and on the other side to the resistor.
So for every 3 white LEDS u need 1 resistor between them, and then continue on? 3 white leds, 1 res? etc?
Old Dec 12, 2005 | 08:33 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The resistor can go anywhere in the circuit because it's the law (Kirkof's series voltage law which states current remains the same in all parts of a series circuit, voltage drops along the way). Resistances in series are additive so if you need 150 ohms you can take two 75 ohm resistors and connect them end-to-end in series.
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
350z82
Oct 1, 2015 06:25 PM
