Nismo Came!!
Old Dec 19, 2005 | 02:24 PM
crazy04350z's Avatar
crazy04350z
Default Nismo Came!!
Nismo Shift **** came in!!!! Was really happy when I heard my door bell becuase I knew that was it...Will post some pics of the **** (Carbon Fiber which looks really sweet!)
Old Dec 19, 2005 | 07:33 PM
crazy04350z
Does anybody have a dern clue how that shift **** comes off. Tried twisting it but dosen't come off but i did not twist it hard cause was scared it might break haha
Old Dec 19, 2005 | 08:00 PM
islandsnow's Avatar
islandsnow
do a search on shift **** install, there's tons. Some had a really hard time taking it off, like me, the **** was practically destroyed. Anyways, if you have someone that can hold the shifter metal shaft with a vice grip while you turn the top **** wrapped in a towel or some rubber innertube type stuff it isn't as bad, but mine was really stuck and i ended up destroying all the leather off the **** and broke some of inner plastic. Also be careful threading on the new nismo ****, i easily stripped the plastic threads when i was tightening the new ****. Anyways, good luck.
Old Dec 19, 2005 | 08:07 PM
crazy04350z
Oh well sorry for what happened, yeah well i might as well try that someone hold the stock while i twist the ****.... Anyone else
Old Dec 19, 2005 | 09:10 PM
meezie's Avatar
meezie
type in "shift **** removal" under the search function. there's quite a few threads that can help you out. good luck.
Old Dec 19, 2005 | 09:24 PM
LiNks's Avatar
LiNks
For some reason i changed mine the other night and i just twisted it right off so easily........ i guess i risked damaging the transmission by turning it hard left but it just broke its seal at a certain point and came right off
Old Dec 20, 2005 | 12:42 PM
crazy04350z
Thanks
Old Dec 20, 2005 | 05:31 PM
crazy04350z
Ok, checked if the plate around the shift popped out and worked, tommorow i am going to pop the whole thing out, but in the direction it says there is radiator hose(where do you find that at)
tell me the steps you did to take out the shift ****
Old Dec 20, 2005 | 06:16 PM
zmegoby's Avatar
zmegoby
I have the carbon fiber one also. It takes a like muscle to get the factory one off but becareful with the factory one because it is worth more than the nismo shift *****.
Old Dec 20, 2005 | 09:09 PM
crazy04350z
so how did u install it do u have a short way of doing it.
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
