An easier way to install clear corners?
Old Jan 20, 2006 | 08:36 AM
Luis_23's Avatar
Luis_23
Default An easier way to install clear corners?
Is there any easier way to install the clear corners or do you have to do it the way they have in the japanese instructions????? Thanks in advance for all the helpful hints
Old Jan 20, 2006 | 08:50 AM
spdu4ia's Avatar
spdu4ia
take the bumper off
Old Jan 20, 2006 | 04:27 PM
mahont's Avatar
mahont
Originally Posted by spdu4ia
take the bumper off
+1
Old Jan 20, 2006 | 04:35 PM
steela2110's Avatar
steela2110
I just took the bumper off... But I have heard that if you take off the bolts the are underneath the bumper (the one's that connect the black panel thing) then you can pull the black panel down and reach the side markers.
Old Jan 20, 2006 | 05:05 PM
momo 350z's Avatar
momo 350z
the drivers side i just turned my wheel in and took off the splash guard 2 or 3 screws that holds it in place,the pass side was a ***** if you have a flex drive that attaches to a drill then it should be easy for you..
Old Jan 21, 2006 | 06:44 PM
___DJK___'s Avatar
___DJK___
The passenger side is torture if you dont take the bumper off.
Old Jan 21, 2006 | 08:59 PM
ares's Avatar
ares
Veteran
all depends on your tool collection.
I think its possible to do it without pulling the wheel wells. but youd need some small hands and even smaller screw drivers. just remove the skid plate and work from there.
removing the wheel wells will make the job much easier.
drivers side is cake at that point. passenger side I personally for full access remove half the bumper screws on that side so it pulls away a little bit, thats plenty. I dont have to remove the whole thing and try and hold it back up by myself later to put it back on.
