Rear Wing price!!! WTF
Does anyone know why this wing is so expensive? And if there is another one like it for cheaper. I like this wing because it is low, not high like all the other CF ones.
because its made of DRY CARBON
all other dry carbon wings are around 1500-2000...
(yes more than entire FRP bodykits)
if you want cheaper but C/F look
check out 3dcarbon.com
they make GT 'C/F' wings
the only difference between that and the high mount is just in the pedistals.
INGs, Voltex, Top Secret, Cwest, all their touring wings are in the $2000+ range. however i do believe ings does make an FRP version for a few hundred less.
you can get a similarly shaped GT wing from APR wing for around 12xx also in carbon, but the pedistal placement is different...
Originally Posted by TIGHT-Z
Yeah i dont mind paying around $1,000. But anything over that, way too much.
Originally Posted by davidf
The negative side to buying a veeerrry exspenive wing like that is some a$$hole will one day want it more than you.
Originally Posted by mdracer76
The SBC is not a cheap club to join
it's a privilege ... not a right.
as for adjustability, its all about the # of holes you drill into the top of your wing pedistal and/or base...
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
