HID install problem, need help
Old Mar 14, 2006 | 05:39 PM
o snap its eric's Avatar
o snap its eric
Default HID install problem, need help
i installed a set of HIDs into my car. Its a plug and play kit and my left side went smooth. My right side is very problematic. The ballast wouldnt light up. So i went ahead and did some troubleshooting. I switched bulbs with my working one and both bulbs are fine but when i plug any of the bulbs to the right side it wouldnt light up. Then i switched ballasts, and both are working fine but when plug any of the ballast to the right side it wouldnt charge up. I even went as far as buying another ballast with the same company and still no work. Did i blow my right headlight fuse or something? Any advice?
PS: my rigth side still has functional fig light and high beam just my low beam with my HID kit doesnt work.
Old Mar 15, 2006 | 06:04 AM
Jun's Avatar
Jun
Fog light? You are talking about a G35 then. Or are you referring to the parking light?
Check your connections and make sure you don't have the cables reversed.
Uriyo_
Sep 8, 2021 08:46 AM
