View Poll Results: What kind of kit would you get?
Fiberglass
24.24%
Duraflex
42.42%
Other
33.33%
Voters: 33. You may not vote on this poll
Fiberglass or Duraflex kit?
Pros and cons of the fiberglass vs the duraflex kits. i know the cons of fiberglass so what are the bad things and or bad experiences people have had with the duraflex kits? mounting issues, and fitment. thanks in advance
i've had good luck with the quality of duraflex. some of the kits dont match up just right but you've got a little play where fiberass your just screwed. i've it it chip and break pretty easy and fitment sux. i would def fun duraflex any day over fiberglass.
duraflex? what are they made of? The question should be: Can you fix duraflex? with fiberglass, you can fix it at anytime. Once again, if your driving skill is good, you shouldn't run into any problem (that cause your kit to break)
I like CF. I've had my front bumper for a while and not only is it strong and slightly flexible, but it seems to deflect bugs better heh. Plus it HAS to fit right the first time.
