How much paint for headlight housings?
Old Mar 20, 2006 | 05:38 PM
d!abolic's Avatar
d!abolic
Default How much paint for headlight housings?
I want to paint my headlight housings. I was thinking of ordering from PaintScratch.com. How much paint do i need? Will one 12.5oz spray can do the trick? Also, do i want a can of primer and a can of clearcoat to go with that?
Old Mar 21, 2006 | 06:16 AM
Jun's Avatar
Jun
a regular-sized spray can is more than enough to give it a few coats on each headlight.
When i did mine in my other car, i didn't use primer/clearcoat, just make sure the spray paint you buy is heat-resistant. The one I purchased was called HOT PAINT that could handle over 500F degrees.
Old Mar 21, 2006 | 01:01 PM
TrucoFitty's Avatar
TrucoFitty
Show Some Pics When U Do It!!!!!!!
Old Mar 21, 2006 | 01:13 PM
A Keno Star's Avatar
A Keno Star
Well what color are you painting it? if you're doing it flat black? then no problem if you're doing it with a gloss dont do it. I did it first with gloss black with clear coat turned out very ****ty. So i took the housing and had a paint shop professionaly paint my housing super black to match my black z and it only cost 40.00 bucks! i'll post pictures later.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
kyin
Oct 15, 2015 05:54 AM
Cashwin
Oct 1, 2015 06:36 AM
JGee450
Sep 30, 2015 04:32 AM
