Painting the ENTIRE 06 headlight housing
Old Aug 15, 2006 | 10:33 AM
Anu2g's Avatar
Anu2g
diabolic, if you go through with painting them red, post pics...i'm interested in seeing how that looks.
Old Aug 31, 2006 | 11:15 PM
creationv2's Avatar
creationv2
this may be dumb....but the process in painting the 06 headlight housing is the same as the 03-05 right? the whooole oven thing?
Old Aug 31, 2006 | 11:16 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Yes
Old Sep 1, 2006 | 12:36 PM
ZlleH's Avatar
ZlleH
I wonder what a blacked out headlight unit would look on a Lemans Sunset car. If I were to get the 06 headlight, I'd definately send it to mrzipps to get that turn signal box thing taken out. Might as well black it out at the same time.
And Nitrouz, what do you get when you order the 06 headlights, does it come with all the bulbs? Does it come with wiring? I heard the signal bulbs are different from 03-05 to 06. More details would be appreciated.
Old Sep 1, 2006 | 01:00 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
I'll take a stab at this since he's out of the country at the moment...
The 06 headlights are plug-n-play so long as you have the HID 03-05 headlights which he did. When purchasing the headlights, I believe it comes with everything you need except for the wiring harness & bulbs (might want to contact someone at Performance Nissan to confirm).
Old Sep 1, 2006 | 01:10 PM
LightWerkz's Avatar
LightWerkz
Originally Posted by d!abolic
I was really impressed by these pictures, and am now considering replacing my 03 headlights (previously damaged) with 06, and painting the ENTIRE housing. Now, is this a good idea? I heard that it wouldn't work with 03's, because they're basically reflector type headlights, but apparently 06's aren't? Is it ok to go through with this? And should i just tell the bodyshop to paint them red / glossy like the rest of the car? Someone mentioned that glossy paint might reflect back, but i think that matte red paint would look really cheap. Suggestions? Pics of the setup i saw are below:
Its okay to go through with it, however you will lose some light output since the low beam is a projector/reflector combo. Let me know if you havey any questions buddy.
Old Sep 1, 2006 | 01:17 PM
abui01's Avatar
abui01
just remember to leave the headlights open for 3+ days for paint to dry otherwise you get that chameleon like gasey film inside ur headlight. Take a look at those pics, you'll see what I mean.
Old Sep 1, 2006 | 01:26 PM
ZlleH's Avatar
ZlleH
So you are basically paying for the housing? You have to buy your own D2S bulbs as well!? Since the 03-05 uses D2R bulbs. That's like another $200 bucks on top of the headlight housing.
Old Sep 1, 2006 | 01:34 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Just confirmed with PN. It comes with everything you need (including the bulbs) & is plug-n-play so long as you previously have the 03-05 HID setup.
Old Sep 1, 2006 | 01:41 PM
ZlleH's Avatar
ZlleH
Thanks!
BTW: I went to the dealers for laughs and asked them how much to order the 06' headlight and they said $1500cdn a piece O.o
Old Sep 1, 2006 | 03:23 PM
LightWerkz's Avatar
LightWerkz
Thats not true. The " Chameleon gasey film" is appearent most likely because the pictures were shot with a polarized lens.
Old Sep 1, 2006 | 04:23 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
+1 & that's exactly what I used when I took Nitrouz's photos.
Old Sep 1, 2006 | 04:45 PM
creationv2's Avatar
creationv2
idk about the camera lens...but my stock 06 headlights have that chameleon film on them depending on the angle....is that not supposed to be?
Old Sep 1, 2006 | 05:04 PM
LightWerkz's Avatar
LightWerkz
A Polarized lens will always have that effect on a headlamp lens.
However its possble to see it in person, or even with a normal lens. Headlamps are trick, tricky to take pics of.
Its normal Creationv2
Old Sep 1, 2006 | 05:59 PM
Built2shredZ's Avatar
Built2shredZ
The Polarized lens does exagerate it, but I do notice a slight chameleon film during mid day at certain angles up close... but its rather minor and didn't notice it at any other time of the day...
Attached Thumbnails Painting the ENTIRE 06 headlight housing-z17.jpg   Painting the ENTIRE 06 headlight housing-z0002.jpg
Old Sep 4, 2006 | 08:51 PM
creationv2's Avatar
creationv2
okay another dumb question....so when you get the headlights painted....you have to do the oven process first and then give them the housing right? or can you just give the whole housing lens and all and they will do it?
Old Sep 4, 2006 | 09:34 PM
masterj26's Avatar
masterj26
send them the housing and they do it
Old Sep 4, 2006 | 11:28 PM
  #38
creationv2's Avatar
creationv2
ah okay....but is that for any bodyshop or jsut the ones that offer the job?
sorry if im making this complicated im just not sure
Old Sep 5, 2006 | 03:25 AM
  #39
LightWerkz's Avatar
LightWerkz
Bodyshops do not do this type of work.
You can contact me if you want more info.
Or check out the site, www.lightwerkz.net
Old Sep 5, 2006 | 05:18 AM
  #40
Nitrouz's Avatar
Nitrouz
Back to Z
the chemeleon film was easily taken off after the photoshoot with some windex.
