Project Double Down Version 2!!! Help me decide...
Originally Posted by 350ZNV
Rampant -Yeah, thats better. Your the man!
I do have the lexan rear window
Originally Posted by Rampant
No problem. I am here to help. Let me know if there is anything else I can do (I happen to love this stuff just a bit too much
Thanks guys! So it looks like the consensus is to keep the CF/Silver thing going. Thats what I was leaning towards anyway since its the cheapest and still looks bad ***.
roast - I will take a look at those kinesis or fiske wheels.
zillinois - I thought widened wheels lose their strength? If not, that will definately be the way to go!
I like the photoshops. The car is looking very cool.
Just an FYI - from everyone I've heard of that owns those Autotecknic mirrors, don't buy them they are cheap junk. The joints at the base and on the mirror come loose at higher speeds and they will constantly be pushed back by the force of the wind. My friend that had them had to take them off he car cause they were driving him crazy and he constantly had to readjust them.
There might be other brands that sell ones that work, but those Autotechnic ones are basically knockoffs and full of problems. I can imagine you wouldn't want them always folding back on you, especially if you're at the track.
you know... you can tighten the bases.. you just have to take the time to take em apart- not too hard.. Gringrott posted the instructions a while back.
even if it is a knock off, the ball joint is a universal piece. i have some pretty stiff suspension, and i'm sure if mine haven't moved yet, they're not gonna shake off on a road course which is most of the time, far smoother than public roads-
Originally Posted by Volk350Z
Well most track Z in japan and the Nissan Demo Z (Red) use 18x10.5 +22 with 285/30/18 all around for track use............
Originally Posted by mraturbo
I just wanted to say YOU ARE A $%@# for not going to Button Willow Friday...
And your G is done...LOL
M
M
. Picking up my G tomorrow AM!
Those look sick my friend! Thanks again.
Originally Posted by zillinois
Widened wheels do not loose their strength as long as they are widened by a professional. If you are unsure, you can always have them xrayed for weld integrity and penetration. If the idea overall doesn't appeal to you, get some custom BBS. They are the best racing wheels you can buy and they might even give you some sponsorship.
^^^Awesome! I will check those out. Thanks!
If you like them let me know. Thinking about selling mine. Regret not going 19's. They're still brand new in box.
Originally Posted by Chebosto
Technosquare ^_^
Technosquare ^_^
Going to have to check them out for a Cage for my G.
Taking the step from street monster to track monster.
Couldn't beat Terry's new Z06 (raced-out) yesterday or that Rolex GT3 race-car. Button-Willow was aesome, JUST TOO HOT...Bakersfield is cool.
Maybe need to try a little harder with Wight reduction, suspension, and a cage...MB, Steve's Mitchel's Red Z looked awesome at Streets, that is what I would do to my Lemans 350z if I didn't have a buyer in Greece.
M
I've got a couple ideas for the wing.
This lets you use hood pin style pins to hold the spoiler on. You just drill a hole through the bolt/stud at a point where the rubber bushing or spring will keep enough force on the spoiler to keep it from moving, but keeping it easy enough to squeeze to put the pin in and not break the pin. The rubber layer between the top piece of aluminum and the trunk lid is to keep the metal from scratching up your c/f trunk. The aluminum can be bought from like home dept or lowes and you shouldn't need an extremely thick piece either. 1/8" should work. You might need to enlist the help of someone with a drill press or a machine shop to drill through the bolt/stud.
OR....
This one's got fewer parts, but it's probably not as "quick" to disconnect since you would have nuts to take on and off. Although fewer parts means fewer pieces to lose.
And if your spoiler base isn't threaded, you would need to secure the bolts to the base using nuts, then use one of the contraptions above.
And to cover the holes off the track, you'd have to find a spoiler similar to the Nismo that has a big base to bolt to. Hope this helps you.
OR....
