Installing the "Fairlady Z" Emblem
Old Aug 11, 2006 | 07:53 AM
shinobi_350z's Avatar
shinobi_350z
Default Installing the "Fairlady Z" Emblem
What is the best way to remove the 350z logo? Are there any holes behind it? Are there OEM Fairlady Z emblems I can get or is it aftermarket?
Old Aug 11, 2006 | 08:26 AM
highside107's Avatar
highside107
Do a search and you'll find your answers.
In short:
Heat the 350z emblem with a hairdryer to "melt" the adhesive behind it. Use floss and slowly work away at the adhesive. Slowly. To remove the adhesive behind it use a product like "Goo Gone".
You can order the emblem from anywhere online. Try courtesyparts.com or mynismo.com
The Fairlady emblem comes with a blue padding/template that lines up with the trunk lines. Seems to be off (tilted down) though. This concern was addressed in the "body / exterior" section recently.
Old Aug 11, 2006 | 12:07 PM
Roger V's Avatar
Roger V
You will need to take it to a body shop to get it installed.
no holes. heat the emblem. pull it off. scrape off sticky. order fairlady z badge from performance nissan.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
