clear corners
Old Aug 17, 2006 | 11:32 AM
Bday350z's Avatar
Bday350z
Default clear corners
how do you take off the front bumper of the z to install the corners? my instructions are in japanese lol
Old Aug 17, 2006 | 12:10 PM
StraySheep's Avatar
StraySheep
You do not need to take off the front bumper to change them. It's more work trying to take the whole front bumper off.
Do a search, it's been asked a few times before.
Just make sure you start with the driver side first, it's a lot easier.
Old Aug 18, 2006 | 02:58 PM
Bday350z's Avatar
Bday350z
i did try to search on it and i couldnt find anything i could only find pictures of peoples clear corners, sorry im a newbie on this forum ive been in the tc and cobalt ss forums before but im still a newb on this one. Could you send me a link to one? and why is the drivers side easier?
Old Aug 18, 2006 | 03:28 PM
Built2shredZ's Avatar
Built2shredZ
Pretty sure it would be easier to just remove the front bumper.. maybe this will help you..
Old Aug 18, 2006 | 07:50 PM
ares's Avatar
ares
Veteran
to remove the bumper, you have to remove the wheel wells, and most of the skidplate screws.
depending on your hand size and tool selection however; you may be able to stop there. (for sure on the drivers side, passenger is a tighter fit).
Old Aug 18, 2006 | 07:54 PM
03Zilverstone's Avatar
03Zilverstone
You don't have to remove the fender wells to take off the bumper, and only the front row of clips in the bottom skid/aero plate thing.
Old Aug 18, 2006 | 07:56 PM
StraySheep's Avatar
StraySheep
https://my350z.com/forum/showthread....lear+reflector
https://my350z.com/forum/showthread....+bumper+marker
These 2 threads should be enough instructions on how to change the bumper reflectors.
Good luck.
Old Aug 18, 2006 | 08:02 PM
StraySheep's Avatar
StraySheep
I don't know about that. Maybe for the 03-05's.
But for the 06's, in order to remove the front bumper, you need to remove 3 bolts close to underneath/beisde the headlight that can only be accessed from the front fenders above the front wheel.
You don't need to remove the entire fender, just part of it to have enough access to undo those 3 bolts.
Old Aug 18, 2006 | 09:54 PM
Bday350z's Avatar
Bday350z
Thanks for all the help guys I think I'll be doing this tomorrow.
Old Aug 24, 2006 | 06:13 PM
MDaniel22's Avatar
MDaniel22
I just got mine from courtesyparts.com. I'm going to try and put them in without removing the bumper. To scared I won't be able to put it back together the right way.
Mines an 06
I'll keep everyone posted.
Old Aug 24, 2006 | 09:05 PM
usmanasif's Avatar
usmanasif
If this doesn't help you, nothing will
https://my350z.com/forum/body-interior-exterior-and-lighting-diy/203246-how-to-front-bumper-removal-l-e-d-clear-corners-install-w-pix-ares-s-06-ccs.html
Old Aug 25, 2006 | 05:59 AM
Bday350z's Avatar
Bday350z
Thanks!! That last thread was exactly what i was looking for! That'll make it pretty simple.
Sleeper_Z
Sep 30, 2015 10:25 AM
