Billet Grill
Old Aug 21, 2006 | 08:20 AM
kdogg24's Avatar
kdogg24
Default Billet Grill
Hey guys, I think I want to put a chrome grill in the front of my 05 blue 350Z. I was on ebay and found a nice billet grill for about $130. Does anyone know how those grills install? How hard they are to install? Drilling required?
Old Aug 21, 2006 | 08:41 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Some use plastic wire ties to attach themselves over the top of the stock grill.
The model I got required that I cut out the stock one using a hacksaw blade. It then attaches to the two plastic pieces on either side of the grill opening using four screws. If I need a two hook put in I remove the four screws from the front and the whole grill comes off and gets put in the trunk.
Old Aug 21, 2006 | 08:43 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
they usually go over the factory grille, and bolt on...
some of the ebay ones are pretty cheap quality without great fittment...
This may be the same or a similar grille...
can be found here...
http://mynismo.com/products/?id=3119
I think this one looks better...
http://mynismo.com/categories/?id=3142
Old Aug 21, 2006 | 08:45 AM
kdogg24's Avatar
kdogg24
Now that's a nice grill! Do you have to drill? How hard is it to drill?
Old Aug 21, 2006 | 08:50 AM
BE350Z's Avatar
BE350Z
I went with i think a 13 bar chrome on my DB. I like it since you dont see it to often. It didnt take any cutting or anything, it connected over the existing plastic and is held on with a retaining bar system you screw in from the back. Due to vibrations I do have to tighten it down about every other month just to be safe though. sorry for the pic link but im at work and cant really log out to get a better pic. http://myspace-808.vo.llnwd.net/0091...18920808_l.jpg
Old Aug 21, 2006 | 08:52 AM
renotahoesteve's Avatar
renotahoesteve
hi i just bought one and installed on my car, it was on ebay for around 100.00 shipped, make sure you get stainless steel, not aluminum if you want it to last there's a pic on the south west forum if you want to see the finished product
zz350zz's Avatar
zz350zz
IMO those look terrible......buy a popcharger instead
Old Aug 21, 2006 | 08:53 AM
ANXIOUZ's Avatar
ANXIOUZ
My grille uses 2 "J" hooks that keep it attached to the stock grille. No drilling, no cutting...take 5 mins to install. I got mine off ebay for like $50 I think. I like it.
This is the only pic I have on this PC...but I think it's the one that Jason posted.
Old Aug 21, 2006 | 10:14 AM
z-u-later's Avatar
z-u-later
That's a similar grille that I have . . . they add some character to my Z, which differentiates it from others. The lines are cleaner also versus the OEM black molded grilles.
Old Aug 21, 2006 | 10:19 AM
HotImportGirl's Avatar
HotImportGirl
I got mine for like $50 and its awesome! Not all of the cheap ones are crappy!
https://my350z.com/forum/showpost.ph...08&postcount=1
Old Aug 21, 2006 | 10:37 AM
ANXIOUZ's Avatar
ANXIOUZ
The front end of my car is so beat up with chips and marks that the grille helps hide some of it...or at least distracts your eyes from noticing the awful paint.
Old Aug 21, 2006 | 10:42 AM
JimmyJaZZ's Avatar
JimmyJaZZ
I bought the B-Cool billet grille, and as Paul350Z mentioned, I had to cut the stock grill out in order to install it. For quick removal, I used hex-head bolts (which look a little slicker than a regular bolt, imo) and wingnuts on the back side. I have had it for almost a year and it's held up great.
Old Aug 21, 2006 | 11:06 AM
HotImportGirl
The newer grills come with that J bracket that clips onto the stock grill, it literally takes 10 mins to install.
Old Aug 21, 2006 | 11:16 AM
kdogg24's Avatar
kdogg24
Can someone attach a link to a product like this?
Old Aug 21, 2006 | 11:40 AM
Jason@Performance
Performance Nissan
+1
Not to mention they block air to the radiator / power steering cooler / etc etc...
But if you were to buy one, buy from my above links...
But I dont recommend... eh...
Old Aug 21, 2006 | 11:43 AM
usmanasif's Avatar
usmanasif
Jason, that link is for the honey-comb grill pattern, not the straight bars.
Old Aug 21, 2006 | 11:46 AM
HotImportGirl
http://search.ebay.com/search/search...e=search&fgtp=
Old Aug 21, 2006 | 12:51 PM
Jason@Performance
Performance Nissan
you know I was thinking that too...
I gotta figure out who added that on our site...
Old Aug 21, 2006 | 02:31 PM
usmanasif's Avatar
usmanasif
Off with their head!
Old Jan 18, 2007 | 08:52 AM
ipodhustle's Avatar
ipodhustle
has anyone ever purchased this one?
pslamp32
Sep 14, 2015 03:05 PM
roadmax
Sep 12, 2015 05:55 PM
