Installed the Varis intake duct today...
Old Aug 22, 2006 | 06:02 PM
  #41
steveiZdaman's Avatar
steveiZdaman
Originally Posted by Takfire
+1 with SPL.
Too bad they discontinued the SPL intake tube.
guess you got the last one
Z-1 did not have them in stock i emailed them asking last week
  #42
steveiZdaman
Originally Posted by NA350Z
It looks very good.
thanks a lot
Old Aug 22, 2006 | 06:18 PM
  #43
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
Talking
Originally Posted by ASTIG_Z
+1 with the black evo-r intake. I really dont want carbon fiber on a black Z.
We have them in stock.
Can be order from here:
http://www.evo-r.net/product/CAI/tube/
Old Aug 23, 2006 | 05:47 AM
  #44
THE TECH's Avatar
THE TECH
I have one of the EVO-R intake tubes for the varis intake if anyone is interested.
Old Aug 23, 2006 | 12:21 PM
  #45
nothingremains's Avatar
nothingremains
how does water not get all in there?
Old Aug 23, 2006 | 01:04 PM
  #46
THE TECH's Avatar
THE TECH
Even if water gets in there, your filter is not going to get soaked. The only way that you could hydrolock the motor with this piece is installed is if your car went underwater.
Old Aug 26, 2006 | 10:41 PM
  #47
mikewagon's Avatar
mikewagon
n e one still have the template they could email me? the one that came with mine is not complete. thanks!
Old Aug 29, 2006 | 03:36 PM
  #48
mikewagon's Avatar
mikewagon
Originally Posted by masterj26
drill the holes then use rivets (sp?), correct?
what exactly are rivets? just got mine and ready to put on, but dont want some idiot to unsrew it off.
Old Aug 29, 2006 | 04:04 PM
  #49
masterj26's Avatar
masterj26
you can get rivets and a rivet gun at home depot or lowes
Old Aug 29, 2006 | 04:57 PM
  #50
steveiZdaman
once you put a rivet in u wont be able to get it off unless you go from the inside i believe
Old Aug 29, 2006 | 06:48 PM
  #51
king67rsss's Avatar
king67rsss
the only way to get a rivet out is to drill off the head
Old Aug 29, 2006 | 06:52 PM
  #52
highside107's Avatar
highside107
Yeah those rivets are tough! That's what I used on my Varis duct.
  #53
JDMZ33's Avatar
JDMZ33
Yea, I would suggest use screws.
Old Aug 31, 2006 | 02:25 PM
  #54
mikewagon's Avatar
mikewagon
i found an install where a he used 3/16th rivets. do i need to drill the holes bigger in the air duct to make this work? thanks.
Old Aug 31, 2006 | 05:53 PM
  #55
Takfire's Avatar
Takfire
I would use extreme caution if you decide to widen the mounting holes in the Varis duct.
It's too easy to chip the material around the mounting holes.
Not sure about the appropriate size pop rivet.
Should be OK as long as the head of the pop rivet is wider than the mounting hole and the shaft of the pop rivet can pass through.
Old Aug 31, 2006 | 06:19 PM
  #56
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by THE TECH
Welcome to the club!
+1
Old Aug 31, 2006 | 08:00 PM
  #57
mikewagon's Avatar
mikewagon
well, the long part of the rivet fits through the air ducts pre-drilled holes perfect. but the 3/16th part doesnt. do i put that part in the drilled bumper holes first, then slide the duct over the rivets, then gun it? man, im confused. its probably really simple. just need to hear from someone that used 3/16.
Old Aug 31, 2006 | 10:13 PM
  #58
iceman21_23's Avatar
iceman21_23
a question how would the varis look on a full cf nismo front bumper
Old Sep 1, 2006 | 03:22 AM
  #59
Takfire's Avatar
Takfire
Mikewagon,
The 3/16 part of the pop rivet is what you would want to pass through the Varis duct and the holes, that are drilled into the bumper.
The button head of the pop rivet should sit flush against the Varis duct.
I suggest a slightly smaller pop rivet if the body of the 3/16 rivet does not fit through the Varis duct.
I made a quick illustration below.
Hope it helps.
Tak
Attached Thumbnails Installed the Varis intake duct today...-varis-duct-install.jpg
Old Sep 1, 2006 | 02:23 PM
  #60
Chebosto's Avatar
Chebosto
shouldnt the duct be more toward the driver side? the intake inlet hole doesnt seem the line up with the CF Duct...
