Very nice. I have a couple of questions though. What are you dropped on? specs in terms of toe, camper, height, etc. As well as wheel specs i.e. size, width, offset and tire size.
Since you haven't gotten your question answered I'll throw in my $.02. The wheels are 19" by the look of the sidewall. The way they're lined up with the fender they are about a +20 offset. I'm guessing the wheels are either 19"x10.5" or 19"x9.5" in the rear and 19"x8.5" up front. I'm sure he's got his toe in check, since hardly anyone will drive their car with bad toe. Camber looks like it's within stock specs. If it's off it's not by much. Hope this helps.
From the pictures i agree that they're 19x9.5 and 19x10.5 and bet they're +22. Tires are probably the standard 245/35 275/35 but i doubt that the rear camber is anywhere near stock spec. Just want to get accurate numbers.
Yes they are 19x9.5 and 19x10.5 +22 all around, and he slammed on stance
suspension. All I know about the camber spec is not anywhere near stock spec now........
