Which Window Part ?
Old Sep 1, 2006 | 06:48 PM
Samurai's Avatar
Samurai
Default Which Window Part ?
How do I know if I should buy a new window motor, window regulator, or window switch ?
My 350Z was one of the first built, #254, and I have 97K miles on it. The driver side window has had some occasional problems where it would not go up, but a second try and it would always go up. A couple of months ago it started not going down. It would not go down for a day or two and then start working again. Finally it got really bad. I took the motor apart, emptied a whole lot of black dust, cleaned the motor and it worked again every time. That was for about a month. Now it's not working again, it won't go down many days, mostly mornings.
I was going to buy a new motor, but I see there is a regulator and a switch. How can I tell if maybe the switch is going bad or the motor ?
BTW, my passenger side window had the go up and come down problem and I've reset that motor twice to get it to keep working.
Old Sep 1, 2006 | 07:02 PM
montarabob's Avatar
montarabob
"Bang" on the inside door trim with your fist. Early stages of fail will allow temp fix. Just like any rotating elect (starter ect) a sharp thump sometimes works. You need a motor.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
_bit
Oct 2, 2015 07:49 AM
