PPW 06 w/ Ichiba Spacers
Old Sep 15, 2006 | 09:29 AM
Spoiled Z's Avatar
Spoiled Z
Default PPW 06 w/ Ichiba Spacers
As you may or may not know I had issues with brake, vdc off and slip coming on after the spacers install. I thought the spacers were the cause but when I took it to the dealership today they said one of the banjo bolt was loose. I'm so relieved that the car is running good now. I have 20mm front and 25mm rear. Anyways here are the pics....
Old Sep 15, 2006 | 10:00 AM
ichibausa's Avatar
ichibausa
Originally Posted by Spoiled Z
I love this photo!
Old Sep 15, 2006 | 10:11 AM
DRFTER_Z's Avatar
DRFTER_Z
What size are your spacers they look real good, and do you just have them on the rear or the fronts as well. Thanks
Old Sep 15, 2006 | 10:12 AM
Spoiled Z's Avatar
Spoiled Z
Thank you Ichiba and for the fast shipping!
Old Sep 15, 2006 | 10:13 AM
Spoiled Z's Avatar
Spoiled Z
I just updated the original thread I forgot to mention I have 20mm front and 25mm rear.
Old Sep 15, 2006 | 10:17 AM
DRFTER_Z's Avatar
DRFTER_Z
Thank you Sir,
Old Sep 15, 2006 | 10:28 AM
Quijano187's Avatar
Quijano187
looks alot nicer , im going to have to pick me up a pair
Old Sep 15, 2006 | 10:33 AM
ichibausa's Avatar
ichibausa
Hope you enjoy!
Old Sep 15, 2006 | 11:44 AM
Spoiled Z's Avatar
Spoiled Z
Thank you Sir,
I'm a girl GRRRR
Old Sep 15, 2006 | 11:59 AM
ichibausa's Avatar
ichibausa
I'm a girl GRRRR
Can't believe it
Old Sep 15, 2006 | 12:31 PM
Spoiled Z's Avatar
Spoiled Z
Originally Posted by ichibausa
Can't believe it
Why not?
Old Sep 15, 2006 | 12:48 PM
DRFTER_Z's Avatar
DRFTER_Z
Whoopsy, sorry............ cars looks awesome.
Old Sep 15, 2006 | 04:38 PM
evolved326's Avatar
evolved326
looks a little PERFECT! nice! been pondering what 06's look liek with spacers.
Old Sep 15, 2006 | 04:42 PM
evolved326's Avatar
evolved326
I am guessing there is no rub?, Also, with ICHIBA, does it come with the studs attached to the spacer already?
Old Sep 15, 2006 | 04:43 PM
driftk1d's Avatar
driftk1d
I'm a girl GRRRR
really?
lol jk
your car looks great
Old Sep 15, 2006 | 06:48 PM
Spoiled Z's Avatar
Spoiled Z
The 20mm front spacers comes with longer studs which will require you to remove the rotors to take off the oem studs. The 25mm rear spacers however has studs attached to it its just a direct bolt on.
Old Sep 15, 2006 | 06:52 PM
evolved326's Avatar
evolved326
Odd. I wonder why they did this.
Old Sep 15, 2006 | 08:08 PM
zman1910's Avatar
zman1910
Do you have to get an alignment after getting spacers?
Old Sep 16, 2006 | 09:32 AM
Spoiled Z's Avatar
Spoiled Z
There is no need because ur not messing with the suspension.
Old Sep 18, 2006 | 04:30 PM
ichibausa's Avatar
ichibausa
25MM is big enough to mount the studs, but 20MM is not safe to mount the studs into the spacer. That's why you have to remove the stock studs when you put in the 20MM or smaller.
