06 swap into 05 headlight/hid help
Old Sep 18, 2006 | 02:10 PM
o snap its eric's Avatar
o snap its eric
Default 06 swap into 05 headlight/hid help
I have a base Z, i did an aftermarket HID upgrade by adding plug and play ballast. I want to add the 06 headlights to my car. Can that be done? If so what do i need to do for a complete swap?
I came across a guy who was willing to trade his 06 headlights with my 05's. So my other question is, can the guy with the 06 headlight be able to use my 05 headlights given that i give him my ballast too?
From the readings i've been doing, i might run into problem because of the number of pin in my harness?
Old Sep 18, 2006 | 02:18 PM
Biochem7's Avatar
Biochem7
Regular
The pin maybe a problem and make sure the 06 lights have a ballast or your bulbs will never turn on
Old Sep 18, 2006 | 09:06 PM
o snap its eric
can anyone confirm?
Old Sep 19, 2006 | 10:45 AM
Jun's Avatar
Jun
your base headlights won't plug into his HID harness.
For you to use his HID headlights in your base 350z, you will need to do some wire-matching (the plugs won't connect directly because of the diff. # of pins).
Old Sep 19, 2006 | 11:20 AM
usmanasif's Avatar
usmanasif
You found someone willing to trade '06 headlights for '05s?
I have read info on the headlight swap here before. Searching will help you.
Old Sep 19, 2006 | 11:39 AM
o snap its eric
surprisingly yes. The guy says the 05's looks meaner while the 06 makes the car look more goofy. I'm not going to dispute his opinons since i want the 06 haha.
Yeah i posted about a swap but i went ahead and just did a hid upgrade. Now i just want to see if there are anymore updated methods in the base 05 headlight swap to an 06 and vice versa.
Old Sep 19, 2006 | 12:53 PM
kdogg24's Avatar
kdogg24
I have been wondering the same thing. I asked local dealers to let me know if they figure out whether or not they fit, still no word....
Old Sep 19, 2006 | 08:46 PM
jinsei888's Avatar
jinsei888
figure this out for me, for sure
Old Sep 20, 2006 | 04:01 AM
Jun's Avatar
Jun
Guys, the plugs ARE different, they won't plug right in, this is a fact.
It doesn't mean you can't get them to work though.
You have to do is figure out what wire is for what, from the HID headlight and from the stock harness, and use some quick splits and tap each wire to the corresponding one (wire for the turn signal from the headlight tap into wire for turn signal from the stock harness, etc, etc). Yeah, it's a little rigged and crap, but that's the way to do it, unless you can find someone to sell you the complete headlight wiring system of the HID Zs, but I believe someone mentioned the dealer does not sell that part.
Old Sep 20, 2006 | 05:39 AM
bleufiend's Avatar
bleufiend
Correct me if im wrong but didnt the whole lineup get HID's in 05.
Are the pins just different from the 05 to the 06 hid setup?
Old Sep 20, 2006 | 06:11 AM
Jun's Avatar
Jun
'03-'05: Base Model=Halogen, The rest=HID
'06: Every model comes with HID
If you have a '03-'05 Enthusiast/Touring/Performance/Track model, you can swap the '06 lights without problems.
Old Sep 20, 2006 | 01:43 PM
bleufiend's Avatar
bleufiend
^^^^my mistake
Old Sep 20, 2006 | 01:49 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
If you car is a BASE model that does not come equipped with HID from the factory, the 2006 headlights WILL NOT work(plug and play). You can hard wire it to make it work, I have seen this done.
Old Sep 20, 2006 | 02:15 PM
Quijano187's Avatar
Quijano187
i completly agree with your friend!
Old Oct 18, 2006 | 06:40 PM
SixRB6's Avatar
SixRB6
Is this a fact?? I have a 04 Touring Roadster and just ordered the 06 headlights and the 06 tails...Will these plug in and play correctly?? I keep reading guys are saying there blinkers are staying on
Old Oct 18, 2006 | 08:06 PM
o snap its eric
just a thought, i was talking to a mechanic, and he told me to look and see if there are any pigtails made to convert the 4pin to a 6pin and vice versa. Has anyone heard anything like this?
Old Oct 18, 2006 | 08:07 PM
SixRB6's Avatar
SixRB6
Originally Posted by mc350z
this is true (sort of) its not the actual blinkers that stay on. that orange bulb has 2 lights in it. one is the "parking light" the other is the brighter flasher. the parking light stays on if you have the 03-05 but the brighter flasher still blinks on and off like a turn signal
there is a thread that tells you how to cut a wire so they wont light up. but honestly imine stay on and i always thought it was supposed to be that way. im leaving mine as is
and yes you have the touring roadster so it has HID that means it is plug ans play
OK I am installing the LED Blinkers from superbrightleds.com....Will that help this problem???
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
SpartanZ32
Oct 22, 2015 09:36 AM
SharX59
Sep 27, 2015 09:23 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
