Sponsored by:
Sponsored by:
Vertical or Gullwing doors
Old 09-21-2006, 12:02 AM
rwalton1129
rwalton1129's Avatar
Default Vertical or Gullwing doors
I was looking at getting vertical doors until I found these Gullwing door kits. They are almost the same price but no one has the Gullwings yet as they were released in late august. What do you guys think?
Pics are at this link.
http://www.gtfactory.jp/flgtfgal/gullwinggallery.htm
Old 09-21-2006, 12:05 AM
kourosH
kourosH's Avatar
i wanna get gullwing!
Old 09-21-2006, 12:09 AM
Marbleshade
Marbleshade's Avatar
Lots of companies call their product gullwing without it actually being so. Gullwing doors are hinged in the roof and open totally vertical. See http://en.wikipedia.org/wiki/Gullwing for more information. The ones at the link you provided are more accurately called butterfly doors. I'd say go with whichever doors you think will look best on your car.
Old 09-21-2006, 12:12 AM
kourosH
kourosH's Avatar
i want butterfly!
Old 09-21-2006, 01:14 AM
JClit
JClit's Avatar
The gullwings look so cheap, i personnally dont like them. Doesnt go with the car at all. Maybe if it was a civic
Old 09-21-2006, 12:04 PM
MustGoFastR
MustGoFastR's Avatar
Yeah, those aren't gullwings. You'd need some pretty extensive bracing in the roof for real gullwings. As long as those butterflys open straight up like that, it's pretty cool. I've always hated how you have to open the doors like normal to a point, then rotate them up for the lambo doors; defeats the purpose, IMO.
Old 09-21-2006, 03:55 PM
MUZZY
MUZZY's Avatar
PROBLEM! I believe it will have problems working since the window goes up a little bit when you open and close the door under the panel on the roof to make a water proof seal. Im afraid you might have tolerance issues. verticals are safe b/c they swing out like normal doors first then they swing up.
Old 09-21-2006, 06:53 PM
rwalton1129
good point MUZZY I did not think about that...
Old 09-21-2006, 09:27 PM
Armitage
Armitage's Avatar
Lame.
Old 09-21-2006, 10:39 PM
Changvi
Changvi's Avatar
neither.
Old 09-22-2006, 08:05 AM
MustGoFastR
I wouldn't think that would be an issue as long as the doors are hung properly. When you pull the handle, the window drops, which will allow the door to swing up and away without problems and the window doesn't go back up until the door is completely closed.
Old 09-22-2006, 08:53 AM
taurran
taurran's Avatar
If you want to see real gullwing doors, look at a DeLorean. In my opinion, that's where they should stay.
Old 09-22-2006, 09:06 AM
MustGoFastR
Agreed. Mercedes did it first, though.
Old 09-22-2006, 09:49 AM
gNaRKiLL
gNaRKiLL's Avatar
I see the the bracket deteriorating over the years, doors are heavy, the mounting points of the stock doors arent made for those kinds of loads.
Not to mention you cant park anywhere normal ever again unless you have 2 a spot open on each side.
I say vertical doors are best if you gonna do it though.
Old 09-22-2006, 10:04 AM
jtabraham
jtabraham's Avatar
I think butterfly doors only look appropriate when the door style isn't "flat" like on our Z, or with just a bare window instead of upper bracing. I think it looks best on the door style of something like a saleen, but for the Z, i would stick to lambo "style" doors
Old 09-22-2006, 10:33 AM
Armitage
Armitage's Avatar
Mmmm... Saleen S7.
Old 09-22-2006, 01:13 PM
CaliTouring
CaliTouring's Avatar
i wonder if they make or if anyone has ever attempted suicide doors on on a Z?
Old 09-22-2006, 04:50 PM
Ianmtx
Ianmtx's Avatar
I never thought of that, would be interesting to see for sure although I would personally never do it.
Old 09-23-2006, 05:32 PM
L33TZOR
L33TZOR's Avatar
not to jack the thread but i asked my bodykit installer about setting up my hood to go like the older 260z i used to own. open at the windshield versus at the front. he just said it would be a real expensive mod.
Do it! Do It!
Old 09-23-2006, 05:44 PM
Armitage
Armitage's Avatar
Why? The RX-8 has suicide doors and the only purpose is to make it easier to get into the back seat. Since the Z lacks a backseat, suicide doors are pointless.
Quick Reply: Vertical or Gullwing doors
