How to take apart 06 center console and dash??
Old Sep 28, 2006 | 03:11 PM
jamesnotworthy's Avatar
jamesnotworthy
Default How to take apart 06 center console and dash??
i've searched and found instructions to take apart center console for pre-06 models, but those instructions dont work on an 06. can someone please teach me how to do this on an 06??
i'm trying to wire interior neons (at footwell) does someone know which wires i can link them up to??
thanks a lot!!
Old Sep 28, 2006 | 03:34 PM
compton's Avatar
compton
i hope your not doing neon tubes.
Old Sep 28, 2006 | 03:42 PM
compton's Avatar
compton
^ hold on, let me elaborate, because i dont want to crush your spirit. first of all what i meant was if you want neons, thats ok i guess. but don't use tubes. trash those tubes! get you some nice led's and a switch. small led's are very easy to hide, and glow much better than neon tubes. the wires shouldnt be too hard for you too hide either, no need to take the dash apart. just combine all the led's into one wire and find a good ground(-). plus led's last much much longer that neon tubes.
Old Sep 28, 2006 | 04:02 PM
Built2shredZ's Avatar
Built2shredZ
http://www.3 5 0 z - t e c h.com/zwiki/Service_Guide
Just remove the spaces They have a 06' service manual in PDF format on that site..
Old Sep 29, 2006 | 12:38 AM
jamesnotworthy
thanks. i downloaded the 2006 service manual from that link, but when i opened it, it's actually the 2005 service manual. those instructions don't work on a 2006.
can someone help me out please??
Old Sep 29, 2006 | 12:50 AM
roast's Avatar
roast
I downloaded it and I'm pretty sure it's the right manual. Why don't you think it will work? It's just the console...
Old Sep 29, 2006 | 01:36 AM
jamesnotworthy
when u open the fwd pdf file, it says that it's for the 2005 z. i tried doing it with those instructions, but it won't work. i guess they must've changed something wiht the 06's.
Old Oct 1, 2006 | 08:57 AM
i8acobra's Avatar
i8acobra
Yep. '06 console is completely different from '05.
Old Oct 1, 2006 | 10:23 AM
xjongsangx80's Avatar
xjongsangx80
I remember did my friend's '05 center consol when he wanted put CF ones..
Now I tried my '06 to fix broken cupholder and this damn thing is
completely different than previous models. I ended up took it to the dealer...they said the 'whole' thing has to come off and it
takes some quite a bit of time..
Old Oct 2, 2006 | 03:28 PM
tmtrino2's Avatar
tmtrino2
I have the same issue. I want to install a navigation system and i need the previous Bose system out of my 2006 grand touring. how can i do this. I cant seem to find info anywhere. Any help is greatly appreciated. Thanks
Old Oct 31, 2006 | 03:00 PM
Nic@CiNcity's Avatar
Nic@CiNcity
ARGHH.. Trying to take the console out of my 04 and can't figure it out! I'm brain dead after all the wiring and engine work i've been doing. Any help on how to take this darn thing out?!
Old Nov 6, 2006 | 04:27 AM
r3zon8's Avatar
r3zon8
Default Relax....
Relax dude, i got you. but the dealer is correct, the entire console comes out.
head over to www.metraonline.com , search for their dashkit for an 06' 350z and youll get 1 hit. Click the link that says 'installation manual' for that dash kit and voila! youll have the 06 dash dissasembly instructions.
OR click here , =)
doesnt look too complicated, especially if you DONT have oem Navi system.
Im getting my Z on wednesday, and ive already got the kit and headunit, avh-p6800dvd, to go into it, so if you like ill post some pics of my install on wednesday/thursday when i do it over in the electronics section.
hope this helps everyone.
Old Nov 6, 2006 | 12:55 PM
Stability's Avatar
Stability
http://liljerk.morpheus.net/350Z/dash_removal/
Go here... I just posted this question for my 06.. It's 99% the same.. the only difference is when you take off the rubber pad in your cubby, on each corner there will be little black covers hiding the screws, pop those off and continue on
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
