Footwell Lighting
Originally Posted by NaNa-Papa-J
I've had fleeting thoughts of switching them out with some blacked out 06 led taillights
-Acree
Acree...always been a huge fan....time for some lighting mods...any suggestions on dome bulbs? Figured I'd do them now that they blew out...any specific brand of neon you recommend for footwell lighting?
Acree, have you ever switched the light in a headunit? I have an Alpine ( blue & green display) and I was wondering if this could be switched?
Originally Posted by jinsei888
those taillights....ugh...
P.S. Keep in mind, I'm planning on doing a custom metallic black/metallic white paint job next year that will incorporate black taillights. However, suggestions are welcome concerning what style of lights to use.
And concerning the neons: Has anyone installed a on/off switch in a location that they recommend?
Ok, ok, ok....it appears that some of my esteemed Z brethren are not fans of my blacked euro taillights.
Any styling suggestions for me on taillights?
Originally Posted by jakesford
Do you think it will look good? who gives a **** what anyone on here thinks its your car, and your money...
For brand of neon tube, I'm not sure if they are "top of the line" or anything, but "Redline" products always did well for me and were very bright.
Originally Posted by xedes
+1
-Acree
Originally Posted by Acree
As far as domelights go, I can not personally recommend any kind of premade LED bulb as all the ones I have bought in the past, burnt out. That's why I just made my own.
It's definitely possible. It's just an issue of getting to the leds. I wouldn't trust myself trying to disassemble any headunit except for stock.
-Acree
-Acree
I have some from autollumination, which are known for burning out, and thats why I don't have them operating when the doors are opened and only use them when I need to. I'd like to have them operate normally.
And would you happen to know what bulb type is for the trunk light?
Originally Posted by Voboy
Hey Acree how much would it set me back if I wanted to purchase some dome lights made by ya?
-Acree
thanks!
Originally Posted by creationv2
haha i came here to chk out the footwell lighting setup and lookie here, acree and more people asking about led stuff :-D
can i get a pm too on acree custom leds :-D hehe
Anyone else, please shoot me a pm yourself, then I will reply with the information you request.
I really hate hi-jacking threads.
-Acree
The "power supply" you refer to is actually the battery.
There is more than plenty of current to power 2 neon tubes. I have 2 15" neon tubes wired into mine, PLUS the leds for my door handles. Everything works just fine.
The wires for the dome light run down the driver side A-pillar. Good luck!
-Acree
There is more than plenty of current to power 2 neon tubes. I have 2 15" neon tubes wired into mine, PLUS the leds for my door handles. Everything works just fine. The wires for the dome light run down the driver side A-pillar. Good luck!
-Acree
so just to clarify, if you wire the lights to the dome light wires in the drivers side a pillar...itll function like the dome light? turns on when doors open....turns on when you switch it on/off in the dome light?
-Acree
Kind of. It will function with the dome lights when you take the key out of the ignition, unlock the car, open the door etc. They will NOT turn on when you push the dome light in. Also, if you turn the switch on the dome light to "Off" instead of "Door," they will STILL come on.
-Acree
-Acree
so other than pushing the dome lights in, or turning the dome lights to "off", the neons will be on whenever the dome lights are on? so like they wont be on while driving?
i can see the point of having the footwell light up with the door opening but what are you trying to look at as u get in the z?? i have never found myself looking at the pedals when i get in or out. just a suggestion or opinion.
i can see making the interior lighting happen as a car locator helper in a busy parking lot, or simply for beautifying cool aestetics for the interior.
-Acree
Like Acree mentioned...it's the Pink wire that's hot (I'm pretty sure...just check it with a voltmeter if you have one...it always pays to doublecheck other's input). Best of luck UofA.
Hey Acree! So you don't like my tail-lights?!
haha I've had fleeting thoughts of switching them out with some blacked out 06 led taillights. However, I'm saving up for a custom paint job and think my current lights might work well with it...we'll see. Thanks for the compliments!!
