Super white LEd interior dome lights
Old Dec 18, 2006 | 05:32 PM
  #61
hr2burn's Avatar
hr2burn
super-TITE! I want a pair! Can I pm you my info or must I order via the site?
Thx, Sean
Old Dec 18, 2006 | 09:18 PM
  #62
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
Thx, Sean
You can order direct from the site. Just make sure when order put a note that you are form my350z.com I will refund you 10 for shipping.
Jay
Old Dec 20, 2006 | 06:30 AM
  #63
Kanyon71's Avatar
Kanyon71
Do you know if the smaller size light you have will fit in the light back in the hatch? I would like to replace that one also.
Old Dec 20, 2006 | 06:36 AM
  #64
JDMZ33's Avatar
JDMZ33
I have another size in 2.7cm by 2.7 cm
Jay
Old Dec 29, 2006 | 10:34 AM
  #65
MustGoFastR's Avatar
MustGoFastR
Just got my dome lights installed. They are NICE! Here are a few pics:
Here's what comes in the package: just about everything you need to mount them in any fixture large enough to house them.
Here's one hooked up:
The driver's side one will pop right in with no problems. I had to lightly modify the passenger side light and housing as seen in the pic below for it to drop in enough to retain the map light switch function (not the shaved corners and shaved housing area at the right shaved corner). If you're going to do this, you need to be very careful not to damage the printed wiring of the board.
Here's a shot comparing the LED light to stock:
As a sidenote, my only concern about these is that the dome light fades (dims) to off 30 sec after you exit the car (or immediately upon locking the car with the fob). LEDs typically don't take well to varying voltage, such as dimming, so we'll have to see how these hold up.
Old Dec 29, 2006 | 10:36 AM
  #66
MustGoFastR
Jay
Aw, man! I should have asked Santa for one of these, too! I was about to ask if there was one that would fit back there; the wedge LED bulb I have in there now is pathetic.
Old Dec 29, 2006 | 03:29 PM
  #67
davidf's Avatar
davidf
I agree with you on the fading part, I guess the trick is upon exit is lock it immediately.
Old Dec 29, 2006 | 05:01 PM
  #68
MustGoFastR
Yeah, maybe; I don't recall if it still fades off when you lock it or not.
Old Jan 2, 2007 | 09:58 PM
  #69
SquallLHeart's Avatar
SquallLHeart
something like that probably doesn't have anything regulating the voltage
so it should still fade.. after the voltage drops below a certain point, the led will just turn off.
it'll be fine
Old Jan 3, 2007 | 10:51 AM
  #70
james840a's Avatar
james840a
Looks nice and bright, thinking about this myself.
Old Apr 14, 2007 | 04:33 PM
  #71
jpne13's Avatar
jpne13
so what was the fuse that you have to change to make the dome lights go on? i know its by the pedals but which one. it doesn't say on the cover. help please
does someone have what each slot does?
Old Apr 14, 2007 | 06:46 PM
  #72
Track's Avatar
Track
Originally Posted by nicholasm617
no, but it would suck to hear it bouncing around in there 24/7
No one ever seemed to address this question, which is a very important one to many of us.
To those who have these installed, do they fit tightly on both sides? Is there a way (or need) to use 3M tape or something to hold them steady?
Old Apr 19, 2007 | 10:26 AM
  #73
Andrea's Avatar
Andrea
I think my 06 z roadster (european model) has different sizes...
Dunno but they seem to be smaller than the pics in here...
Also the switch and the frame are different, the're black not gray...
for JDMZ33: something that fits my Z? Without cutting, shaving, modifying at all... Price? I don't expect any discount as I'm in Italy...
By the way, i got some of the new Luxeon K2 leds... 6watts each led... Yesss, SIX watts each one, but careful:
the light they produce is cool (u won't feel heat, no IR frequencies), and astonishing, but they actually came to me mounted on a 3x3 cm aluminium plate, which, after less than 5mins, becomes really really hot (no way to touch it) .
I bought them for some interior lighting ideas, but actually no way to use them, i think they will blow plastics...
Old Apr 19, 2007 | 10:47 AM
  #74
MarkM's Avatar
MarkM
US has 2 interior colours, Frost and charcoal, in Europe, just charcoal
Old Apr 19, 2007 | 03:36 PM
  #75
Andrea's Avatar
Andrea
Mmm... And no AT available... Just level 1 and level 2 available... No mp3 radio... Windows don't go up and down with key fob... And it costs 47000euros (more or less 64k dollars)...
Daaamn...
And (the cherry on the cake) gas is 1,65dollars/liter... Standard 95 octanes gas...
However... Know something about the size? Is mine/roadster's smaller?
Thank you
Old Apr 26, 2007 | 01:46 PM
  #76
350ZIvy's Avatar
350ZIvy
It is kind of too bright......I got the simply type of LED bulbs for the Map lights around 10 bucks on ebay. Pretty good quality. You guys can check it out too.
this guy's ebay store is http://stores.ebay.com/MotoringMax.
Old Apr 26, 2007 | 01:49 PM
  #77
350ZIvy's Avatar
350ZIvy
Do you know how thick, the length and the width of this LED panel? thx a lot
Old Apr 26, 2007 | 01:53 PM
  #78
r0mey's Avatar
r0mey
dood that is hot
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
